Home » Eclipse Projects » e(fx)clipse » MenuContribution not working
MenuContribution not working [message #1736349] Tue, 28 June 2016 17:16 Go to next message
Robert Onslow is currently offline Robert OnslowFriend
My MenuContribution defined in a fragment is not showing, so I tried a dummy MenuContribution in the main Application.e4xmi as attached
This didn't work either
I have checked the Parent-ID and can't see where the problem lies. Can anyone see where the problem is?
Robert
Re: MenuContribution not working [message #1736361 is a reply to message #1736349] Tue, 28 June 2016 20:10 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
MenuContribution is a concept for the Compat-Layer and should have never
leaked to e4.
There are many replacements in e4 on JavaFX. So if you describe your
usecase we might be able to help.
Tom
> Thanks
> Thanks
> Robert
Re: MenuContribution not working [message #1736362 is a reply to message #1736361] Tue, 28 June 2016 20:20 Go to previous messageGo to next message
Tom
Thank you so much for your response.
I need to add a Direct Menu Item specified in a model fragment in another bundle to a menu specified in Application.e4xmi
Robert
Re: MenuContribution not working [message #1736406 is a reply to message #1736362] Wed, 29 June 2016 09:49 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph KeimelFriend
Hi Robert,
you don't need a MenuContribution to do this. You can add the DirectMenuItem directly to your menu in the fragment:
1) Add a Model Fragment
2) Enter the ID of your menu in "Extended Element ID" (or use "Find" and search for the Menu element you want to extend)
3) Enter "children" in the Feature Name
4) Add a DirectMenuItem to the list
Your fragment will look something like this:
<?xml version="1.0" encoding="ASCII"?>
<fragment:ModelFragments xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:fragment="http://www.eclipse.org/ui/2010/UIModel/fragment" xmlns:menu="http://www.eclipse.org/ui/2010/UIModel/application/ui/menu" xmi:id="_blYVoKyIEeCKFuMJDXQFqw">
  <fragments xsi:type="fragment:StringModelFragment" xmi:id="_Yi6YEHl5EeGH0NZcAx6uwg" featurename="children" parentElementId="my.menu.id" positionInList="">
    <elements xsi:type="menu:DirectMenuItem" xmi:id="_LteIkD3eEeawmcVIUMHCiA" elementId="my.extended.menuitem.0"/>
  </fragments>
</fragment:ModelFragments>
Christoph
Re: MenuContribution not working [message #1736498 is a reply to message #1736406] Wed, 29 June 2016 20:15 Go to previous message
Thanks Cristoph
Previous Topic:EMenuService.registerContextMenu causes NullPointerException
Next Topic:How to get EMF-Edit for JavaFX
Current Time: Tue Aug 03 17:30:30 GMT 2021
Powered by FUDForum. Page generated in 0.01610 seconds
