Re: Java reverse update site? [message #1737516 is a reply to message #1737229] |
Fri, 08 July 2016 21:42 |
Allan Kinnaird Messages: 3 Registered: July 2016 |
Alas Benoit - not completely! I can do most of what I want but I can't flag a class as a Java class or a property as a Java property. The "generate Java code" action (which has to come from a right-click on the model area and doesn't appear in any menu) then only produces bare code, without getters and setters. If I uninstall the Neon components and re-install from the papyrus/mars site as Harald Kornmayer suggests then I get what I expect (including appropriate Java action entries under the Papyrus menu). Fyi, what I'm using as an intro to Papyrus is Mad Sailor's series of UML tutorials, so where I'm having an immediate problem is in <https://www.youtube.com/watch?v=gmf8CswqKcs >, from about 12 minutes onwards. I'm aware that this is a complex transition and that things will not be communicated correctly in the course of the change, so please don't feel attacked by suggestions that everything is not perfect! You're doing an amazing job!
[Updated on: Sat, 09 July 2016 00:50] Report message to a moderator
FUDForum. Page generated in 0.02266 seconds
