Home » Modeling » Papyrus » How to reference or associate a stereotype to a transition in a state machine?
How to reference or associate a stereotype to a transition in a state machine? [message #1735962] Fri, 24 June 2016 05:06 Go to next message
Syed Samsul Arefin is currently offline Syed Samsul ArefinFriend
Assume, I have a stereotype called 'Failure Category'. Now in the state machine for some transitions, I would like to instantiate 'Failure Category' stereotype to represent the category of the failure if that transition encounters any error.
Is that possible in papyrus? If so, how? Or
Is there any other (better) way to do that?
Thank you very much.
Re: How to reference or associate a stereotype to a transition in a state machine? [message #1736016 is a reply to message #1735962] Fri, 24 June 2016 12:35 Go to previous message
Christian Damus is currently offline Christian DamusFriend
If your profile is applied to some package containing (indirectly or
not) your state machine, then you can use the Profile tab in the
Properties view to apply stereotypes. Just select the transition in
your state machine diagram, then in the Profile tab in Properties hit
the green '+' button to apply a stereotype.
HTH,
Christian
On 2016-06-24 05:06:50 +0000, Syed Samsul Arefin said:
> Hello,
> Is there any other (better) way to do that? Thank you very much.
Previous Topic:How to add parameters for a trigger in state machine?
Next Topic:Use of filters in NewChild/CreationMenuModels?
Current Time: Thu Aug 06 13:21:35 GMT 2020
Powered by FUDForum. Page generated in 0.01576 seconds
