ONC 2015 S&CC Vocabulary Validation [message #1735633] |
Tue, 21 June 2016 13:57 |
Jason Countryman Messages: 4 Registered: June 2016 |
Good morning, and thank you for your time.
I'm working on creating my own validator output from the MDHT base for upcoming MU3 certification.
When comparing my results to the Edge Testing Tool 2.1 validator, the implementation guide (IG) results are exactly the same in my validator (using MDHT) as the ETT gets. However, the ETT also has ONC 2015 errors and warnings as well, that I don't get out of a simple CDAUtil.load() result.
Is there something simple here I need to perform? I'm using the NT_Bad_AllergyReactionElements_r21_v1.xml that you can get from the ETT as my test document. I've tried several different methods with the load, and still get usually the same results.
Do I, perhaps, have to validate on a section level to get those results, or are they not even part of MDHT?
Thank you,
Jason
FUDForum. Page generated in 0.03901 seconds
