Adding a new edge in a diagram extension [message #1735589] |
Tue, 21 June 2016 06:51  |
Hi all,
currently I'm working on my master's thesis and got a little stuck during the implementation of a diagram extension.
First of all, I got a core meta-model and an extension which are built in a way that the extension knows the core meta-model but the core meta-model doesn't know the extension. There is a root meta-class in the core as well as in the extension while the root class in the extension extends the root class in the core so that I can create and choose all elements from both meta-models.
However, I also created a new relation in the extension that connects two elements in the core meta-model together. Both elements are represented by my base editor. For the representation of the extension I created a diagram extension as I don't want to alter the base editor directly (Since not everybody needs to use my extension). Is there any way where I can create the new edge in the extension and refer to the node mappings of the base editor if the extension and the base editor are both in separate .odesign files?
And, if there is no way in doing so, is there another way of creating that specific edge without altering the base editor?
Hope my request isn't too confusing.
Greetings,
Michael
Re: Adding a new edge in a diagram extension [message #1735756 is a reply to message #1735752] |
Wed, 22 June 2016 09:26  |
I'm not sure to understand your problem.
In example I was given you, the root element in the representation
DiagramExtension or in Diagram2Extension is extension.Root. In
DiagramCore the root is core.Root. It's not the same object.
If extension.Root does not extend core.Root, does not change the Sirius
mechanism. So, you can remove the extension of core.Root in
extension.Root. I tested it in example I was given you and it's work!
Is that also possible when using the diagram extension mechanism Sirius
offers and if
the extension root element only references, but not extends the core
root class? Yes!
As far as I know the root node in the odesign extension is the same as
in the core odesign.
No! In odesign extension it's extension.Root and in core odesign it's
core.Root.
Julien - Obeo
FUDForum. Page generated in 0.04745 seconds
