Home » Modeling » TMF (Xtext) » xtext not showing latest dependencies for org.eclipse.emf.ecore.xcore(xtext not showing latest dependencies for org.eclipse.emf.ecore.xcore)
xtext not showing latest dependencies for org.eclipse.emf.ecore.xcore [message #1735502] Mon, 20 June 2016 08:52 Go to next message
My xtext project not showing xtext dependencies of latest version for org.eclipse.emf.ecore.xcore. It is showing org.eclipse.emf.ecore.xcore1.1.1 but my xtext version is 2.9. How can I solve this issue?
Re: xtext not showing latest dependencies for org.eclipse.emf.ecore.xcore [message #1735557 is a reply to message #1735502] Tue, 21 June 2016 03:32 Go to previous messageGo to next message
There are several p2 repositories which might have to be considered. Best you define a target platform with the Xcore SDK feature and try the appropriate one.
Xcore 1.3.0: http://download.eclipse.org/modeling/emf/emf/updates/releases/
Xcore 1.3.2: https://hudson.eclipse.org/xtext/job/emf-xcore-maintenance/lastSuccessfulBuild/artifact/build-result/p2.repository/
Xcore 1.4.0: https://hudson.eclipse.org/xtext/job/emf-xcore/lastSuccessfulBuild/artifact/build-result/p2.repository/
Likely you need to use the latest version together with 2.9. I haven't tested it.
Xcore is not participating in the official Eclipse release train so far and I did not find other official repositories besides the Hudson build.
~Karsten
Re: xtext not showing latest dependencies for org.eclipse.emf.ecore.xcore [message #1735590 is a reply to message #1735557] Tue, 21 June 2016 07:04 Go to previous message
Note that you can use Oomph's repository explorer to find Eclipse update
sites:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#How_to_find_a_P2_repository_at_Eclipse_using_the_Repository_Explorer
The example used in the wiki happens to be for Xcore...
Probably using update sites from Hudson builds isn't so great because
those update sites are slow and aren't mirrored.
> Xcore 1.3.0:
> Xcore 1.3.2:
> Xcore 1.4.0:
> tested it.
> build.
> ~Karsten
Previous Topic:Inferring XMemberFeatureCall
Next Topic:[mwe2] unmapped paths platform:/resource/
Current Time: Sun Mar 23 14:42:41 EDT 2025
Powered by FUDForum. Page generated in 0.05841 seconds
