Re: Can't install eclipse [message #1735586 is a reply to message #1735484] |
Tue, 21 June 2016 10:44 |
Ed Merks Messages: 33140 Registered: July 2009 |
If you bring up a command prompt window and type "java -version", what
does that tell you? I.e., what is the default Java version being used
by this computer? The installer also looks in the registry for all the
registered Java installations, so if you're seeing this message, it's
not finding one with the right bitness or of a high-enough version
anywhere, including not on the default system path.
On 20.06.2016 09:29, Fitz Fitz wrote:
> Hi everyone.
> It seems that i'm unable to install eclipse on this office computer i
> just installed. So here's the problem. I downloaded JDK 8.92 (64 bits)
> and installed it. I downloaded the default eclipse installer for 64
> bits and all I get when trying to install it is this page :
> http://download.eclipse.org/oomph/jre/?vm=1_1_7_0_64_0
> "Java for Windows missing"
> I checked and this computer got a 64 bits windows 7.
> Does anyone got an idea?
> Thanks in advance!
Ed Merks
FUDForum. Page generated in 0.09640 seconds
