Home » Newcomers » Newcomers » Stable repository URLs for R and SRx releases?
Stable repository URLs for R and SRx releases? [message #1735313] Fri, 17 June 2016 10:06 Go to next message
Rolf Theunissen is currently offline Rolf TheunissenFriend
Is there any stable URL to an update site that does not contain the latest service release of an release, but points to a fixed version of a release?
For EPP packages such a link does exist:
http://download.eclipse.org/technology/epp/packages/mars/R/
Is there something similar for the whole release? For instance, to download Mars.0
http://download.eclipse.org/releases/mars/R/
Re: Stable repository URLs for R and SRx releases? [message #1735324 is a reply to message #1735313] Fri, 17 June 2016 11:34 Go to previous messageGo to next message
Ed Merks is currently online Ed MerksFriend
Rolf,
Oomph's Repository Explorer can help find repositories.
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#How_to_find_a_P2_repository_at_Eclipse_using_the_Repository_Explorer
The release train repos are generally composites. So
http://download.eclipse.org/releases/mars composes three children:
201506241002, 201510021000, and 201602261000. I.e., generally the date
of the release.
> a release?
> download Mars.0 http://download.eclipse.org/releases/mars/R/
Re: Stable repository URLs for R and SRx releases? [message #1735335 is a reply to message #1735324] Fri, 17 June 2016 12:32 Go to previous messageGo to next message
Ed, thanks for your answer.
Looking at the composite repository, http://download.eclipse.org/releases/mars includes the children: 201506241002, 201510021000, and 201602261000. However it also includes 'http://download.eclipse.org/technology/epp/packages/mars/'.
The EPP update site is not a composite, but it does include sub-dirs (repros) for each of the releases.
So to get the consistent behavior, I have to depend two repositories on:
- http://download.eclipse.org/releases/mars/201506241002/
- http://download.eclipse.org/technology/epp/packages/mars/SR1
For convenience, it would be nice to have an update site that composes the two update sites above. For some automatic builds, I would like to chose which moment to upgrade, not the moment the updates are available. Having that convenience update site would be really helpfull.
Kind Regards,
Rolf
Re: Stable repository URLs for R and SRx releases? [message #1735340 is a reply to message #1735335] Fri, 17 June 2016 12:48 Go to previous message
Rolf,
You can always create your own composite so that your build uses a
single update site that composes the site(s) you want it to find and
that you update the moment you want what the build finds to change.
Also note that the EPP main site is an aggregate, so I believe you can
always point at that, but if you point at only a child of the release
train, it can only install the corresponding EPP versions, even though
all the EPP versions are visible in the aggregate (because their
corresponding release train things aren't visible they can't be installed).
> Kind Regards,
> Rolf
Previous Topic:SOAP Webservice Client in Eclipse
Next Topic:RSE: php files do not store on remote site
Current Time: Sat Jul 04 13:41:10 GMT 2020
Powered by FUDForum. Page generated in 0.03180 seconds
