Home » Modeling » OCL » Define allInstances() operation for Signals
Define allInstances() operation for Signals [message #1735185] Thu, 16 June 2016 08:20 Go to next message
Denis Nikiforov is currently offline Denis NikiforovFriend
Hi!
I need to write and parse constraints of the form:
Signal1.allInstances()->notEmpty()
where Signal1 is an instance of uml::Signal
I don't need to execute them, instead I need only an AST.
The problem is that I get the error:
Unresolved Static Operation 'test::Signal1::allInstances()'
It seems that signals doesn't have allInstances() operation. Here is a request with a test project and more details:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=496210
Is it possible to define this operation programmaticaly as a workaround? I'm trying to define the operation for all signals in the model programmaticaly:
        TreeIterator<EObject> iter = uml.eAllContents();
        while (iter.hasNext()) {
            EObject obj = iter.next();
            if (obj instanceof Signal) {
                try {
                    org.eclipse.ocl.pivot.Signal signal = ocl.getMetamodelManager().getASOf(org.eclipse.ocl.pivot.Signal.class, obj);
                    org.eclipse.ocl.pivot.Operation asOperation = PivotFactory.eINSTANCE.createOperation();
                    org.eclipse.ocl.pivot.CollectionType returnType = PivotFactory.eINSTANCE.createSetType();
                    returnType.setElementType(signal);
                    TemplateSignature sign = PivotFactory.eINSTANCE.createTemplateSignature();
                    TemplateParameter param = PivotFactory.eINSTANCE.createTemplateParameter();
                    sign.getOwnedParameters().add(param);
                    returnType.setOwnedSignature(sign);
                    returnType.setLower(0);
                    returnType.setUpper(-1);
                    returnType.setOwningPackage(umlAS);
                    signal.getOwnedOperations().add(asOperation);
                    asOperation.setName("allInstances");
                    asOperation.setIsStatic(true);
                    asOperation.setType(returnType);
                } catch (ParserException e) {
                    e.printStackTrace();
Here is a full project https://github.com/AresEkb/allInstances_test Just uncomment the operation creation code. But something is wrong:
org.eclipse.ocl.pivot.utilities.SemanticException: The 'test::Signal1' constraint is invalid: 'Signal1.allInstances()->notEmpty()'
1: java.lang.IllegalStateException
	at org.eclipse.ocl.pivot.utilities.PivotUtil.checkResourceErrors(PivotUtil.java:144)
	at org.eclipse.ocl.pivot.internal.context.AbstractParserContext.parse(AbstractParserContext.java:154)
	at org.eclipse.ocl.pivot.internal.helper.OCLHelperImpl.createInvariant(OCLHelperImpl.java:113)
	at org.eclipse.ocl.pivot.utilities.OCL.createInvariant(OCL.java:261)
Could you suggest the right way to define allInstances() programmaticaly?
Re: Define allInstances() operation for Signals [message #1735213 is a reply to message #1735185] Thu, 16 June 2016 11:08 Go to previous message
A fix is described in https://bugs.eclipse.org/bugs/show_bug.cgi?id=496210
Please add comments to the bug for any relevant part of this that is not
addressed.
Modifying loaded metamodels is very dangerous since the current manually
written support almost certainly has missing code to refresh caches.
The Pivot OCL supports open classes, whereby a CompleteClass is an
overlaid merge of many partial classes. You should therefore create a
new Model/Package/Class/Operation hierarchy and install it. The easiest
way may be to load a Complete OCL document. This will certainly give you
some clues as to what you need to do and may point you at some helper
routines. Most notably, your handcrafted return type specialiization is
very deficient. It should be a shared singleton in the orphanage.
Ed Willink
On 16/06/2016 09:21, Denis Nikiforov wrote:
> Hi!
> try {
> obj);
> at
> at
> at
Previous Topic:[oclinecore] import statement gets rewritten
Next Topic:Announcing OCL 6.1.0 (and 6.2.0) for Neon
Current Time: Wed Feb 26 08:29:05 GMT 2020
Powered by FUDForum. Page generated in 0.02078 seconds
