Exception: org.eclipse.swt.SWTException: Widget is disposed [message #1735167] |
Thu, 16 June 2016 04:40 |
Minnie P Messages: 15 Registered: January 2013 |
Junior Member |
Im trying to run my test suite and I get an exception after the 1st test is run.
I tested on RCPTT 2.0.2, 2.1.0 p2 install/2.0.2, 2.1.0 RCP Testing Tool IDE and see the same exception consistently.
Has anyone seen this error/issue before? I think this is a serious bug.
Any help is appreciated guys! Thanks in advance!
Exception happened:
at org.eclipse.swt.SWT.error(SWT.java:4441)
at org.eclipse.swt.SWT.error(SWT.java:4356)
at org.eclipse.swt.SWT.error(SWT.java:4327)
at org.eclipse.swt.widgets.Widget.error(Widget.java:476)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:348)
at org.eclipse.swt.widgets.Menu.setLocation(Menu.java:1458)
at org.eclipse.rcptt.tesla.internal.ui.player.ChildrenCollectingSession.collectMenuItems(ChildrenCollectingSession.java:343)
at org.eclipse.rcptt.tesla.internal.ui.player.ChildrenCollectingSession.collect(ChildrenCollectingSession.java:224)
at org.eclipse.rcptt.tesla.internal.ui.player.ChildrenCollector.collectFor(ChildrenCollector.java:73)
at org.eclipse.rcptt.tesla.internal.ui.player.ChildrenCollector.collectFor(ChildrenCollector.java:64)
at org.eclipse.rcptt.tesla.internal.ui.player.ChildrenCollector.collectFor(ChildrenCollector.java:44)
at org.eclipse.rcptt.tesla.internal.ui.player.SWTUIPlayer.selectMenu(SWTUIPlayer.java:1429)
at org.eclipse.rcptt.tesla.internal.ui.player.SWTUIPlayer.select(SWTUIPlayer.java:317)
at org.eclipse.rcptt.tesla.internal.ui.processors.SWTUIProcessor.select(SWTUIProcessor.java:2133)
at org.eclipse.rcptt.tesla.internal.core.TeslaProcessorManager.select(TeslaProcessorManager.java:87)
at org.eclipse.rcptt.tesla.internal.core.AbstractTeslaClient.handleSelect(AbstractTeslaClient.java:110)
at org.eclipse.rcptt.tesla.internal.core.AbstractTeslaClient.execute(AbstractTeslaClient.java:287)
at org.eclipse.rcptt.tesla.internal.core.AbstractTeslaClient.doOneCommand(AbstractTeslaClient.java:233)
at org.eclipse.rcptt.tesla.internal.core.AbstractTeslaClient.processNext(AbstractTeslaClient.java:130)
at org.eclipse.rcptt.tesla.ecl.impl.TeslaBridge$2.doProcessing(TeslaBridge.java:101)
at org.eclipse.rcptt.tesla.swt.events.TeslaEventManager.doProcessing(TeslaEventManager.java:109)
at org.eclipse.rcptt.tesla.swt.aspects.DisplayAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_DisplayAspect$1$e269b158(DisplayAspect.aj:87)
at org.eclipse.swt.widgets.Display.sleep(Display.java:4693)
at org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(WorkbenchAdvisor.java:368)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.eventLoopIdle(IDEWorkbenchAdvisor.java:918)
at org.eclipse.ui.internal.Workbench$3.eventLoopIdle(Workbench.java:502)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1155)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:677)
Minnie
[Updated on: Thu, 16 June 2016 04:43] Report message to a moderator
FUDForum. Page generated in 0.04696 seconds
