Home » Archived » Jubula » Cannot Install Jubula API Convertor
Cannot Install Jubula API Convertor [message #1735114] Wed, 15 June 2016 11:35 Go to next message
I am trying to install Jubula API Convertor by following instructions given at
http://help.eclipse.org/mars/topic/org.eclipse.jubula.client.ua.help/content/html/developerManual/clientAPI/converter.html
However, I get following error on Install Details page and can't continue ahead.
Cannot complete the install because one or more required items could not be found.
Software being installed: Jubula Functional Testing - API Converter (experimental) 4.0.0.201510211215 (org.eclipse.jubula.feature.api.converter.feature.group 4.0.0.201510211215)
Missing requirement: Jubula API - Converter 4.0.0.201510211215 (org.eclipse.jubula.client.api.converter 4.0.0.201510211215) requires 'bundle org.eclipse.jubula.toolkit.api.gen [4.0.0,4.1.0)' but it could not be found
Cannot satisfy dependency:
From: Jubula Functional Testing - API Converter (experimental) 4.0.0.201510211215 (org.eclipse.jubula.feature.api.converter.feature.group 4.0.0.201510211215)
To: org.eclipse.jubula.client.api.converter [4.0.0.201510211215]
My Jubula version is 8.2.0.021
Re: Cannot Install Jubula API Convertor [message #1735174 is a reply to message #1735114] Thu, 16 June 2016 01:53 Go to previous messageGo to next message
Hi Irfan,
This appears to be the same bug as here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=482517
It's fixed in later versions.
Alex
Re: Cannot Install Jubula logic Identifier [message #1737047 is a reply to message #1735174] Tue, 05 July 2016 05:57 Go to previous messageGo to next message
I too have the same problem as irfan .I could not install logic identifier .
I got following error:
Software being installed: Feature 1.0.0.201607051151 (org.eclipse.jubula.examples.extensions.rcp.gef.logic.identifier.feature.feature.group 1.0.0.201607051151)
My Jubula version is 8.2.2.055
Can please help me.
Re: Cannot Install Jubula logic Identifier [message #1737148 is a reply to message #1737047] Wed, 06 July 2016 03:00 Go to previous messageGo to next message
Hi Rohit,
the installation of the API-Converter works perfectly fine for me in 8.2.2.055.
What seems quite odd is, that the feature you are trying to install has a 1.0.0.x version, although the current feature version that is shipped with Jubula 8.2.2.055 is a 4.0.0.x version.
Please make sure that you are installing the feature from the development/org.eclipse.jubula.repo.zip repository as described in our development manual.
Kevin
Re: Cannot Install Jubula logic Identifier [message #1737594 is a reply to message #1737148] Mon, 11 July 2016 02:20 Go to previous message
Thank you Kevin for support it worked.
Best Regards,
Rohit
Previous Topic:Eclipse RCP Jacoco .exec file
Next Topic:Classify exit code after test execution
Current Time: Thu Jun 12 12:40:09 EDT 2025
Powered by FUDForum. Page generated in 0.03474 seconds
