How to open bpmn files properly [message #1735047] |
Tue, 14 June 2016 22:31  |
Delacyr Ferreira Messages: 20 Registered: February 2016 |
I'm trying to open bpmn files programmatically, but without success until now. First, I'm getting the URI (java.net.URI) from bpmn file, but method BPMN2Editor.openEditor(modelURI) has another implementation of URI as parameter (org.eclipse.emf.common.util.URI).
Facing this question, I did a conversion from java.net.URI to o.e.emf.common.util.URI.
java.net.URI javanetURI = project.getFolder("FolderName").getFile("FileName").getLocationURI();
org.eclipse.emf.common.util.URI modelURI;
modelURI = org.eclipse.emf.common.util.URI.createURI(javanetURI.toString());
BPMN2Editor.openEditor(modelURI);
But even this way, when I called openEditor method, I got the "Failed to create the part's controls" error.
I don't know whats going on. Hope someone have a tip for this.
Thank you,
Delacyr
[Updated on: Tue, 14 June 2016 22:35] Report message to a moderator
Re: How to open bpmn files properly [message #1735150 is a reply to message #1735051] |
Wed, 15 June 2016 21:40  |
Thank you Bob, it helped me and now it works. The new code follows below.
IPath path_BPDFolder = project.getFolder("FolderName").getFullPath().append("FileName");
modelURI = org.eclipse.emf.common.util.URI.createPlatformResourceURI(path_BPDFolder.toString(), true);
[Updated on: Wed, 15 June 2016 21:41] Report message to a moderator
FUDForum. Page generated in 0.02083 seconds
