Home » Eclipse Projects » GEF » Custom Property Sheet listener and events(Custom Property Sheet listener and events)
Custom Property Sheet listener and events [message #1734732] Fri, 10 June 2016 18:01 Go to next message
swaroop shastri is currently offline swaroop shastriFriend
I have created a customproperty sheet in GEF for my ecore model
public class MyProperty extends AbstractPropertySection...
It has some text boxes, which are connected to element (ecore model) on canvas. If I change say label/name of element in canvas , it reflects on the property sheet and vice versa.
The issue is, when I change any text , it does not fire following code present on the canvas....could you tell me how to set dirty flag for this operation?
public void commandStackChanged(EventObject event) {
firePropertyChange(PROP_DIRTY);
Thanks in advance
Re: Custom Property Sheet listener and events [message #1743709 is a reply to message #1734732] Mon, 19 September 2016 07:44 Go to previous message
Matthias Wienand is currently offline Matthias WienandFriend
When using the Eclipse UI AbstractPropertySection, no undoable commands are generated. Therefore, you should use org.eclipse.gef.ui.properties.UndoablePropertySheetPage as an alternative so that undoable commands are created for property changes.
Matthias
Previous Topic:Handle on Mouse event for gef.graph.Node
Next Topic:GEF4 Add extra visual elements
Current Time: Thu Jan 16 16:34:38 GMT 2025
Powered by FUDForum. Page generated in 0.03864 seconds
