Home » Modeling » Epsilon » [EVL live validation not done](Live validation rule in generated diagram editor is not trigerred when saving the diagram.)
[EVL live validation not done] [message #1734719] |
Fri, 10 June 2016 15:43 |
Alexandre Honorat Messages: 8 Registered: February 2016 |
Hi all,
I'm new to Epsilon tool suite, so I'm sorry is the solution is obvious ! (I've been trying to use directly GMF first, and then Sirius, and then I've tried Eugenia + EVL which seems pretty easy to use).
So I've created an EVL validation plugin but the rule is not applied or not shown (the well-known red icon is not displayed on the unnamed eclass): the rule simply is the constraint example to check if an attribute is set. The provided filesystem example is working fine, so I probably missed something in the configuration of my own validator or in the genmodel/gmfgen. I've attached all the relevant files (validator plugin.xml, validator evl file, ecore file, genmodel file and gmfgen file). Particularly notice that:
- "Decoration" editor's attribute is set to "Live" in .genmodel
- "Live Validation UI Feedback", "Validation Decorators" and "Validation Enabled" are all set to true (Diagram's attributes of Gen Diagram GraphEditPart) in .gmfgen
- Ns URI is "adfgGraphModel" everywhere
- validation evl file is well included in the binary build (file not attached).
So any idea of what I miss to set ? (or what I set wrong ...) Thanks for your help !
PS: I'm using Epsilon with eclipse modeling mars, but it's probably not the cause since the filesystem example works fine
Re: [EVL live validation not done] [message #1734990 is a reply to message #1734971] |
Tue, 14 June 2016 13:42 |
the problem is still there, I've joined the archive with the ecore/emf/gmf project and the validator module . The Epsilon version I use is : 1.3.0.201602270002 .
I originally have generated the gmfgen file with Eugenia, but I've slightly modified it (for the variables I mentioned in my previous post), same thing for the genmodel file. So I do not generate the code with Eugenia: I only generate the gmf files; then I generate the code from the gmfgen file.
Some explanations on what the project is about: the ecore define a directed graph with Actors and Channels to modelize processes and communications. I'd like to check if names (and later some other properties) are indeed defined in order to tell the user: ok your model is correct, I can transform it. It works fine with the ecore editor (which detects if the Name attribute is absent, and if a unique ID key is present more than once). I would like to have the same validation for the diagram, and currently I've tried for Name definition with EVL, but no error is shown when creating an Actor/Channel without Name.
I think I've simply wrongly set some parameters but, as a beginner, I don't know which ones ... Thanks for your help !
Re: [EVL live validation not done] [message #1735644 is a reply to message #1735641] |
Tue, 21 June 2016 14:45 |
Hi Alexandre,
> it seems that the following sentence is outdated
Thanks. I've fixed this now.
> is it possible to reduce the scope only to the diagram editor
I don't think that this is possible. EVL actually integrates with the EMF validation framework so the integration with GMF comes almost for free.
Dimitris
Current Time: Fri Mar 29 07:00:14 GMT 2024
Powered by FUDForum. Page generated in 0.02784 seconds
