Re: Problem during loading the created model [message #1734631 is a reply to message #1734622] |
Fri, 10 June 2016 06:39 |
Ed Merks Messages: 33140 Registered: July 2009 |
You can edit the eclipse.ini to add the appropriate VM option:
http://stackoverflow.com/questions/3700459/how-to-increase-the-java-stack-size
On 10.06.2016 06:59, naveen ramesh wrote:
> Problem when creating the model object.I have the ecore model
> BasicFamily.ecore and the genmodel BasicFamily.genmodel.Now for the
> BasicFamily.genmodel the model,edit and editor code is generated.Once
> the code is generated i run the eclipse application for the generated
> editor code and in that application i started creating the modelling
> project and for that project when i try to create family model defined
> in the BasicFamily.ecore it used to throw the exception as mentioned
> below
> java.lang.StackOverflowError
> at java.lang.ClassLoader.defineClass1(Native Method)
> at java.lang.ClassLoader.defineClass(Unknown Source)
> at
> org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272)
> at
> org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632)
> So after research in the internet it is mentioned that for
> recursive call the stack size mentioned is not enough for the
> eclipse.So how can i increase the size of the stack.
> Thanks in advance
Ed Merks
FUDForum. Page generated in 0.02798 seconds
