Home » Modeling » M2T (model-to-text transformation) » i an unbable to set value for type attribute in class diagram using papyrus plugin(i try to set datatype for class atributes in my class diagram but it is not showing any attributes how ican set )
i an unbable to set value for type attribute in class diagram using papyrus plugin [message #1734201] Mon, 06 June 2016 07:03 Go to next message
hardeep kaur is currently offline hardeep kaurFriend
and i am unable to import java datatypes in my class diagram can anybody help me for this
  • Attachment: newwaatt.PNG
    (Size: 113.94KB, Downloaded 209 times)
Re: i an unbable to set value for type attribute in class diagram using papyrus plugin [message #1734331 is a reply to message #1734201] Tue, 07 June 2016 08:48 Go to previous messageGo to next message
Right-click the root of your model in the Model Explorer view.
Then in the menu Import->Registered Package.
Lastly, in the dialogue choose JavaPrimitiveTypes.
Best,
Víctor López
Re: i an unbable to set value for type attribute in class diagram using papyrus plugin [message #1734339 is a reply to message #1734331] Tue, 07 June 2016 09:31 Go to previous messageGo to next message
i didn't get the import option on right click
  • Attachment: noimport.png
    (Size: 106.72KB, Downloaded 228 times)
Re: i an unbable to set value for type attribute in class diagram using papyrus plugin [message #1734341 is a reply to message #1734339] Tue, 07 June 2016 10:00 Go to previous messageGo to next message
Please, read the messages more carefully.
I wrote in the Model Explorer, not in the Project Explorer.
Show that view using the Window menu.
Best,
Víctor López
Re: i an unbable to set value for type attribute in class diagram using papyrus plugin [message #1734344 is a reply to message #1734341] Tue, 07 June 2016 10:21 Go to previous messageGo to next message
im also doing that in model explore please check the attachment
    (Size: 23.98KB, Downloaded 436 times)
Re: i an unbable to set value for type attribute in class diagram using papyrus plugin [message #1734347 is a reply to message #1734344] Tue, 07 June 2016 10:48 Go to previous messageGo to next message
I don't know what Papyrus version are you using.
Right-clicking in the root of the model (a profile model in your case)
works for me to import the types.
Best,
Víctor López
Re: i an unbable to set value for type attribute in class diagram using papyrus plugin [message #1734407 is a reply to message #1734347] Wed, 08 June 2016 05:36 Go to previous messageGo to next message
i'm using 1.1.4.2 version of papyrus
Re: i an unbable to set value for type attribute in class diagram using papyrus plugin [message #1734425 is a reply to message #1734347] Wed, 08 June 2016 10:42 Go to previous message
im using 1.1.4.2 version of papyrus.
help me to draw the uml diagram its urgent for me or please send me the link of the version which i used to get the import option and tell me if any other plugin is required for that
Previous Topic:JET tag library documentation?
Next Topic:Re: Acceleo loop problem
Current Time: Fri Jan 17 12:48:48 GMT 2025
Powered by FUDForum. Page generated in 0.03563 seconds
