Home » Eclipse Projects » Sapphire » show/hide outline elements during runtime
show/hide outline elements during runtime [message #1733979] Thu, 02 June 2016 15:12 Go to next message
Reinhart Herzog is currently offline Reinhart HerzogFriend
Hi Konstantin,
can outline-menu-elements be hidden and shown during runtime? The outline-elements to be shown/hidden have no representation in the edited xml-file.
kind regards, reinhart
Re: show/hide outline elements during runtime [message #1733990 is a reply to message #1733979] Thu, 02 June 2016 16:44 Go to previous message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
You can control visibility of most UI parts, including the outline nodes, by using the "visible when" facility, which takes a Sapphire EL expression. You can find documentation on Sapphire EL in Sapphire Developer Guide.
Here is an example from the Architecture Sketch Editor in Sapphire Samples. If you look through samples, you will find other examples of Sapphire EL usage for the visible when and other purposes.
index.php/fa/26053/0/
  • Attachment: Capture.PNG
    (Size: 24.99KB, Downloaded 465 times)
Previous Topic:Access xml file-path from PossibleValuesService or ListPropertyBinding implementation
Next Topic:Stop Column Sorter in a List Property Editor
Current Time: Tue Jan 19 13:15:23 GMT 2021
Powered by FUDForum. Page generated in 0.01879 seconds
