Home » Language IDEs » Java Development Tools (JDT) » JDT Compiler: Inherited annotations are not visible on bridge methods (works in older version)
JDT Compiler: Inherited annotations are not visible on bridge methods (works in older version) [message #1733811] Wed, 01 June 2016 03:08 Go to next message
Since upgrading to Eclipse Version Mars.1 Release (4.5.1) i'm facing a problem where the code being generated by the Eclipse compiler is missing annotations from the base class. When compiling with the OpenJDK compiler these annotations are created correctly. The JDT plugin version is: 3.11.1.v20150904-0015.
I assume this is pretty much the same issue which was fixed for the OpenJDK Compiler with issue JDK-6695379.
The class files generated via the Eclipse compiler are missing annotations for inherited public methods which were set on the base class.
In particular this fails for the @TransactionAttribute in a JEE project.
Differences in the class files:
On the superclass (with package visibility) of the given file @TransactionAttribute(NOT_SUPPORTED) was set on method doSomething():
#13 = Utf8               RuntimeVisibleAnnotations
#14 = Utf8               Ljavax/ejb/TransactionAttribute;
#15 = Utf8               value
#16 = Utf8               Ljavax/ejb/TransactionAttributeType;
#17 = Utf8               NOT_SUPPORTED
  public void doSomething();
    descriptor: ()V
    flags: ACC_PUBLIC, ACC_BRIDGE, ACC_SYNTHETIC
    Code:
      stack=1, locals=1, args_size=1
         0: aload_0
         1: invokespecial #2                  // Method de/thaenert/test/BeanSuperclass.doSomething:()V
         4: return
      LineNumberTable:
        line 10: 0
      LocalVariableTable:
        Start  Length  Slot  Name   Signature
            0       5     0  this   Lde/thaenert/test/Bean;
    RuntimeVisibleAnnotations:
      0: #14(#15=e#16.#17)
For the compiled code from the Eclipse compiler with the same source code and java version the annotation is missing:
    descriptor: ()V
    Code:
         0: aload_0
         1: invokespecial #15                 // Method de/thaenert/test/BeanSuperclass.doSomething:()V
         4: return
      LineNumberTable:
        line 1: 0
      LocalVariableTable:
As specified in JSR 318: EJB 3.1 section 13.3.7.1 i would have expected that this annotation is also visible on the subclass.
Is this something known already?
When using an older version of the JDT plugin this does not happen (Version 3.10.1.v20150204-1700)
Best Regards
Ralf Thaenert
Re: JDT Compiler: Inherited annotations are not visible on bridge methods (works in older version) [message #1733972 is a reply to message #1733811] Thu, 02 June 2016 10:31 Go to previous messageGo to next message
Ralf Thaenert wrote on Wed, 01 June 2016 09:08
Thanks for the reference. This would map to https://bugs.eclipse.org/437446 which was closed as a dup of https://bugs.eclipse.org/427745 which in turn was marked as resolved for Eclipse 4.4.
As we thought this issue is resolved, can you please file a bug with
- the source code that triggers this
- a link to the two above bugs for comparison
That's an odd version, in that range I have 3.10.1.v20140902-0626 and 3.10.2.v20150120-1634
But in fact using a similar example (from the JDK-bug) I didn't see annotations on the bridge with any of these ecj version.
Stephan
Re: JDT Compiler: Inherited annotations are not visible on bridge methods (works in older version) [message #1734064 is a reply to message #1733972] Fri, 03 June 2016 08:57 Go to previous message
Hey Stephan,
i put in https://bugs.eclipse.org/495396 and attached a sample project to that bug.
Thank you for the quick response!
Best Regards
Ralf
Previous Topic:Can Eclipse Mars communicate with RaspBerry pi 2 like NetBean can
Next Topic:How to get rid of special characters in the console output?
Current Time: Fri Jun 20 19:43:28 EDT 2025
Powered by FUDForum. Page generated in 0.08176 seconds
