Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733569] |
Mon, 30 May 2016 08:25 |
chris yo Messages: 146 Registered: February 2013 |
I have an xtext grammar, and I created an xcore model for my grammar.
In my .xtext file, I removed this line:
generate myDsl "http://mydsl.org"
and I added this line:
In my GenerateMydsl.mwe2 file:
I added the following:
bean = StandaloneSetup {
scanClassPath = true
platformUri = "${runtimeProject}/.."
// The following two lines can be removed, if Xbase is not used.
registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
// Register my packages
registerGeneratedEPackage = "mydsl.MydslPackage"
registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
registerGenModelFile = "platform:/resource/xtext/model/generated/Mydsl.genmodel"
MyDslPackage is in emf-gen directory, which is automatically generated from my mydsl.xcore file.
I have read that I would need to register the GenModel, so I created a new genmodel from mydsl.xcore by doing this:
right click on mydsl.xcore -> new -> other -> EMF generator model -> Mydsl.genmodel -> xcore -> load -> tick the entry in root packages -> finish.
I am not sure if this is still needed, though.
Inside the Generator component for language, I added these:
loadedResource = "platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore"
loadedResource = "platform:/resource/xtext/model/generated/mydsl.ecore"
loadedResource = "platform:/resource/xtext/src/org/MyDsl.xcore"
I have also commented this line:
//fragment = ecore.EMFGeneratorFragment auto-inject {}
My plugin.xml also have this entry:
<extension point="org.eclipse.emf.ecore.generated_package">
<!-- @generated Mydsl -->
<package
uri="mydsl"
class="mydsl.MydslPackage"
genModel="src/org/Mydsl.xcore"/>
</extension>
I was able to generate the jar file, but when I run it, I get this error:
java.lang.IllegalStateException: Unresolved proxy classpath:/org/mydsl#//Directory. Make sure the EPackage has been registered.
What am I doing wrong?
I am not very familiar with xcore and would appreciate any suggestions.
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733580 is a reply to message #1733578] |
Mon, 30 May 2016 09:43 |
if you create a new project using the wizard in 29x+ youll get something like
module org.xtext.example.mydsl.GenerateMyDsl
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "org.xtext.example.mydsl"
rootPath = rootPath
runtimeTest = {
enabled = true
eclipsePlugin = {
enabled = true
eclipsePluginTest = {
enabled = true
createEclipseMetaData = true
code = {
encoding = "UTF-8"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = StandardLanguage {
referencedResource = "platform:/resource/demox/model/demox.xcore"
name = "org.xtext.example.mydsl.MyDsl"
fileExtensions = "mydsl"
serializer = {
generateStub = false
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
which i customized with a single line
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733591 is a reply to message #1733580] |
Mon, 30 May 2016 10:47 |
Hi Christian,
This is the contents of my workflow. It looks different from what you are showing me.
Workflow {
component = DirectoryCleaner {
directory = "${runtimeProject}/src-gen"
directory = "${runtimeProject}.ui/src-gen"
component = Generator {
pathRtProject = runtimeProject
projectNameRt = projectName
language = auto-inject {
uri = "platform:/resource/xtext/src/org/MyDsl.xtext"
// Java API to access grammar elements (required by several other fragments)
fragment = grammarAccess.GrammarAccessFragment auto-inject {}
// generates Java API for the generated EPackages
// switch to xcore
// fragment = ecore.EMFGeneratorFragment auto-inject {}
// Serializer 2.0
fragment = serializer.SerializerFragment auto-inject {
// the serialization component (1.0)
// fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
// a custom ResourceFactory for use with EMF
fragment = resourceFactory.ResourceFactoryFragment auto-inject {}
// The antlr parser generator fragment.
fragment = parser.antlr.XtextAntlrGeneratorFragment auto-inject {
options = {
backtrack = true
classSplitting=true
fieldsPerClass = "1200"
methodsPerClass = "1200"
// java-based API for validation
fragment = validation.JavaValidatorFragment auto-inject {
// composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
// generator API
fragment = generator.GeneratorFragment auto-inject {
generateMwe = false
generateJavaMain = true
// rename refactoring
fragment = refactoring.RefactorElementNameFragment auto-inject {}
// provides the necessary bindings for java types integration
fragment = types.TypesGeneratorFragment auto-inject {}
// generates the required bindings only if the grammar inherits from Xbase
fragment = xbase.XbaseGeneratorFragment auto-inject {}
// provides a compare view
fragment = compare.CompareFragment auto-inject {}
Does this mean I have to change my workflow to the one you gave me?
I did not create a new project. My project is already existing from an older version, and I just exported it to the newer Eclipse version that I have.
[Updated on: Mon, 30 May 2016 10:48] Report message to a moderator
FUDForum. Page generated in 0.03463 seconds
