Home » Modeling » TMF (Xtext) » Unresolved proxy classpath.. Make sure the EPackage has been registered.
Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733569] Mon, 30 May 2016 08:25 Go to next message
chris yo is currently offline chris yoFriend
I have an xtext grammar, and I created an xcore model for my grammar.
In my .xtext file, I removed this line:
generate myDsl "http://mydsl.org"
and I added this line:
import "mydsl"
In my GenerateMydsl.mwe2 file:
I added the following:
    bean = StandaloneSetup {
            scanClassPath = true
            platformUri = "${runtimeProject}/.."
            // The following two lines can be removed, if Xbase is not used.
            registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
            // Register my packages
            registerGeneratedEPackage = "mydsl.MydslPackage"
            registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
            registerGenModelFile = "platform:/resource/xtext/model/generated/Mydsl.genmodel"
MyDslPackage is in emf-gen directory, which is automatically generated from my mydsl.xcore file.
I have read that I would need to register the GenModel, so I created a new genmodel from mydsl.xcore by doing this:
right click on mydsl.xcore -> new -> other -> EMF generator model -> Mydsl.genmodel -> xcore -> load -> tick the entry in root packages -> finish.
I am not sure if this is still needed, though.
Inside the Generator component for language, I added these:
loadedResource = "platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore"
            	loadedResource = "platform:/resource/xtext/model/generated/mydsl.ecore"
            	loadedResource = "platform:/resource/xtext/src/org/MyDsl.xcore"
I have also commented this line:
//fragment = ecore.EMFGeneratorFragment auto-inject {}
My plugin.xml also have this entry:
   <extension point="org.eclipse.emf.ecore.generated_package">
      <!-- @generated Mydsl -->
      <package
            uri="mydsl"
            class="mydsl.MydslPackage"
            genModel="src/org/Mydsl.xcore"/>
   </extension>
I was able to generate the jar file, but when I run it, I get this error:
java.lang.IllegalStateException: Unresolved proxy classpath:/org/mydsl#//Directory. Make sure the EPackage has been registered.
What am I doing wrong? Sad
I am not very familiar with xcore and would appreciate any suggestions.
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733570 is a reply to message #1733569] Mon, 30 May 2016 08:40 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
which xtext version do you use and which style of workflow?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733578 is a reply to message #1733570] Mon, 30 May 2016 09:39 Go to previous messageGo to next message
Hi Christian,
This is the xtext version I am using.
Xtext Complete SDK 2.9.1.v201512180746 org.eclipse.xtext.sdk.feature.group Eclipse Xtext
EMF - Eclipse Modeling Framework Xcore SDK 1.3.2.v20160209-0349 org.eclipse.emf.ecore.xcore.sdk.feature.group Eclipse Modeling Project
What do you mean by "which style of workflow"? I am still new in this xcore stuffs so I am not sure of the style of workflow.
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733580 is a reply to message #1733578] Mon, 30 May 2016 09:43 Go to previous messageGo to next message
if you create a new project using the wizard in 29x+ youll get something like
module org.xtext.example.mydsl.GenerateMyDsl
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "org.xtext.example.mydsl"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			referencedResource = "platform:/resource/demox/model/demox.xcore"
			name = "org.xtext.example.mydsl.MyDsl"
			fileExtensions = "mydsl"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
which i customized with a single line
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733591 is a reply to message #1733580] Mon, 30 May 2016 10:47 Go to previous messageGo to next message
Hi Christian,
This is the contents of my workflow. It looks different from what you are showing me.
Workflow {
        component = DirectoryCleaner {
            directory = "${runtimeProject}/src-gen"
            directory = "${runtimeProject}.ui/src-gen"
        component = Generator {
            pathRtProject = runtimeProject
            projectNameRt = projectName
            language = auto-inject {
                uri = "platform:/resource/xtext/src/org/MyDsl.xtext"
                // Java API to access grammar elements (required by several other fragments)
                fragment = grammarAccess.GrammarAccessFragment auto-inject {}
                // generates Java API for the generated EPackages
                // switch to xcore
                // fragment = ecore.EMFGeneratorFragment auto-inject {}
                // Serializer 2.0
                fragment = serializer.SerializerFragment auto-inject  {
                // the serialization component (1.0)
                // fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
                // a custom ResourceFactory for use with EMF
                fragment = resourceFactory.ResourceFactoryFragment auto-inject {}
                // The antlr parser generator fragment.
                fragment = parser.antlr.XtextAntlrGeneratorFragment auto-inject {
                  options = {
                      	backtrack = true
                        classSplitting=true
                        fieldsPerClass = "1200"
                        methodsPerClass = "1200"
                // java-based API for validation
                fragment = validation.JavaValidatorFragment auto-inject {
                //    composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
                // generator API
                fragment = generator.GeneratorFragment auto-inject {
                    generateMwe = false
                    generateJavaMain = true
                // rename refactoring
                fragment = refactoring.RefactorElementNameFragment auto-inject {}
                // provides the necessary bindings for java types integration
                fragment = types.TypesGeneratorFragment auto-inject {}
                // generates the required bindings only if the grammar inherits from Xbase
                fragment = xbase.XbaseGeneratorFragment auto-inject {}
                // provides a compare view
                fragment = compare.CompareFragment auto-inject {}
Does this mean I have to change my workflow to the one you gave me?
I did not create a new project. My project is already existing from an older version, and I just exported it to the newer Eclipse version that I have.
[Updated on: Mon, 30 May 2016 10:48]
Report message to a moderator
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733592 is a reply to message #1733591] Mon, 30 May 2016 10:48 Go to previous messageGo to next message
Sry I don't know the answer to this question
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733797 is a reply to message #1733592] Wed, 01 June 2016 03:16 Go to previous messageGo to next message
Thanks Christian! I will just update my workflow and see if it works.
Just wondering, is it necessary to set the resourceSet?
[Updated on: Wed, 01 June 2016 03:17]
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733802 is a reply to message #1733797] Wed, 01 June 2016 04:45 Go to previous messageGo to next message
it was is the old <= 2.8.4 style workflow
Re: Unresolved proxy classpath.. Make sure the EPackage has been registered. [message #1733803 is a reply to message #1733802] Wed, 01 June 2016 05:36 Go to previous message
Somebody might be interested..
I managed to get it working by following the steps here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=379999 (see comment#12).
Basically, I missed the EPackage registration in the MyDslStandAloneSetup (Step 6).
Previous Topic:quickfix for referenced object not found
Next Topic:How to register Packages in the global EPackage.Registry Instance?
Current Time: Fri Sep 18 11:54:13 GMT 2020
Powered by FUDForum. Page generated in 0.02403 seconds
