Home » Modeling » TMF (Xtext) » How to combine to different plugins(How to combine to different plugins)
How to combine to different plugins [message #1733349] Thu, 26 May 2016 13:39 Go to next message
I have two different plugins in two different eclipse ide. How can I integrate them?
Can anyone explain?
Re: How to combine to different plugins [message #1733379 is a reply to message #1733349] Fri, 27 May 2016 01:41 Go to previous messageGo to next message
What do you mean by integrate
Re: How to combine to different plugins [message #1733393 is a reply to message #1733379] Fri, 27 May 2016 04:20 Go to previous messageGo to next message
I have created xtext plugin for my editor. And also I created one custom project plugin which contains my own folder structure. So I want to combine editor nature for my custom project. I can do it individually by installing two plugins separately but I want to apply the xtext editor nature to my custom project plugin.
Re: How to combine to different plugins [message #1733396 is a reply to message #1733393] Fri, 27 May 2016 04:40 Go to previous messageGo to next message
I don't get the question. You can deploy many plugins to your runtime
eclipse
Re: How to combine to different plugins [message #1733397 is a reply to message #1733396] Fri, 27 May 2016 05:01 Go to previous messageGo to next message
I will explain clearly. I have exported xtext plugin as zip folder. And I want to add this plugin to runtime of my custom project plugin
Re: How to combine to different plugins [message #1733410 is a reply to message #1733397] Fri, 27 May 2016 05:44 Go to previous messageGo to next message
Since the terms are still ambiguous what do you mean by "adding a plugin to
the runtime of another plugin"
You can add plugins to an eclipse installation only.
Or do you mean adding xtext nature and xtext builder to a project in
eclipse workspace
Re: How to combine to different plugins [message #1733414 is a reply to message #1733410] Fri, 27 May 2016 06:07 Go to previous messageGo to next message
Yes I want xtext nature and xtext builder to a project in
eclipse workspace.
Re: How to combine to different plugins [message #1733419 is a reply to message #1733414] Fri, 27 May 2016 06:22 Go to previous messageGo to next message
let you inspire by org.eclipse.xtext.builder.nature.ToggleXtextNatureAction.toggleNature(IProject)
org.eclipse.xtext.ui.wizard.AbstractProjectCreator and other places
Re: How to combine to different plugins [message #1733448 is a reply to message #1733419] Fri, 27 May 2016 11:10 Go to previous message
It is working. Thanks
Previous Topic:Parse a text with selfdescribing rules
Next Topic:Simple gradle xtext generator example?
Current Time: Tue Mar 25 00:47:36 EDT 2025
Powered by FUDForum. Page generated in 0.08434 seconds
