Home » Eclipse Projects » BPMN 2.0 Modeler » Validation Error Decorations do not show
Validation Error Decorations do not show [message #1733195] Wed, 25 May 2016 06:23 Go to next message
Hi all,
as the title says, the validation error decorations do not show up for me.
It works in the xml editor/the source view (the errors/hints do get annotated at the start of the line), but not in the graphical editor.
I am using a custom runtime extension (which doesn't do anything yet) and the bpmn2 project nature.
Did I forget to add something to my extension so the validator will work? I tried to follow the developer tutorials. There are also no error messages in the log.
If needed I will gladly provide additional information.
Thanks in advance.
Re: Validation Error Decorations do not show [message #1733333 is a reply to message #1733195] Thu, 26 May 2016 10:01 Go to previous messageGo to next message
Hmm, that's odd. The BPMN2 validator, which is responsible for creating Problem records, should be invoked whenever you save a file, or if you click "Validate" on the context menu. Can you verify if BPMN2ProjectValidator.validate() is being called when you save/validate a file?
icon11.gif  Re: Validation Error Decorations do not show [message #1733435 is a reply to message #1733333] Fri, 27 May 2016 08:42 Go to previous messageGo to next message
Thanks for your answer.
After going through the debugger on the validate method I found my error in the url:
platform:/resource//folder/diagram.bpmn
Hint: After resource there should only be one "/", the other one somehow sneaked in while assembling the url. Funny how that didn't really affect anything else..
Thanks again for your help Smile
Re: Validation Error Decorations do not show [message #1733491 is a reply to message #1733435] Sat, 28 May 2016 08:43 Go to previous message
Awesome Smile glad I was able to help.
Previous Topic:change color with code
Next Topic:Neon M2 build is not available
Current Time: Fri Jul 18 04:03:16 EDT 2025
Powered by FUDForum. Page generated in 0.28840 seconds
