Home » Eclipse Projects » Nebula » repository location(nebula repository is on the move ?)
repository location [message #1733176] Tue, 24 May 2016 23:38 Go to next message
Erik Vande Velde is currently offline Erik Vande VeldeFriend
Member
Since quite some time we were using this url in our tycho build for nebula:
http://download.eclipse.org/technology/nebula/archives/Q12015/release
On monday we found out that the link was not valid any more, and we should now use http://archive.eclipse.org/technology/nebula/Q12015/release/
Today, Wednesday, none of both work. What are we supposed to use today ?
Re: repository location [message #1733179 is a reply to message #1733176] Wed, 25 May 2016 07:33 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
We are in the process of a graduation release that was long overdue. The release of Nebula 1.0.0 is scheduled for June 1st.
In that process we also clean up the repositories we had so far. It seems that by cleaning up and moving them something broke. The discussion can be followed here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=494079
It seems something went wrong with the move and the linking.
Re: repository location [message #1733353 is a reply to message #1733179] Thu, 26 May 2016 18:29 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
We have moved the nebula archives from [1] to [2] and we will most likely never move again.
All links are up.
[1] http://downloads.eclipse.org/technology/nebula/archives
[2] http://archive.eclipse.org/nebula
See also the nebula downloads page
## Why?
We stored our archives on the normal download site causing them to be mirrored.
Wim
Re: repository location [message #1733741 is a reply to message #1733353] Tue, 31 May 2016 10:28 Go to previous message
To be clear, [1] has been discontinued.
Previous Topic:Filterrow does not reveal full cell on edit
Next Topic:[RichTextEditor] Missing icons in the palette when widget is calling by a plugin
Current Time: Fri Apr 19 15:40:16 GMT 2024
Powered by FUDForum. Page generated in 0.02221 seconds
