Re: SubApp Error [message #1733359 is a reply to message #1733338] |
Thu, 26 May 2016 13:35 |
yes 4DIAC provides you only the IEC 61499 system view. But you can access all the files also from your file explorer 4DIAC stores everything in plane xml files. You can easily save this files away for backup or add them into a version control system. I would recommend one of both.
Regarding your project. I spent some time looking through your project files. I don't know what happened here. After working a while with the files I could get a bit back from you when I deleted all devices (see attached project). What I didn't manage to bring back was the broken subapplication in your reconfiguration application. I'm very sorry that this happened and hope that this helps at least a bit.
Do you have more information on what steps you did? This could really help us to stabilize 4DIAC for future releases.
FUDForum. Page generated in 0.03747 seconds
