Home » Modeling » Papyrus » How to get an image out of a Papyrus diagram ?
Re: How to get an image out of a Papyrus diagram ? [message #1733358 is a reply to message #1733192] |
Thu, 26 May 2016 19:12   |
Laurent Le Moux Messages: 44 Registered: June 2015 |
Member |
Hi Camille,
Thank you for your answer. I changed my code to reproduce the behavior of Papyrus 'ExportAllDiagramsEngine' as follow (where the diagramName string is actually a path like '/path/to/model'...) :
// Copy / paste of ExportAllDiagramsEngine.initialiseModelSet()
ServicesRegistry service = new ServicesRegistry();
// Add service factory for Model Set
ServiceDescriptor descriptor = new ServiceDescriptor(ModelSet.class, ModelSetServiceFactory.class.getName(), ServiceStartKind.STARTUP, 10);
descriptor.setServiceTypeKind(ServiceTypeKind.serviceFactory);
service.add(descriptor);
// Add factory for editing domain
descriptor = new ServiceDescriptor(TransactionalEditingDomain.class, EditingDomainServiceFactory.class.getName(), ServiceStartKind.STARTUP, 10, Collections.singletonList(ModelSet.class.getName()));
try {
service.startRegistry();
} catch (ServiceMultiException e) {
throw new BirtException(e.getMessage());
ModelSet modelSet = null;
try {
modelSet = ServiceUtils.getInstance().getModelSet(service);
} catch (ServiceException e) {
// Add CDO resources in order for modelSet.loadModels not to fail...
CDOResource diResource = view.getResource(diagramName + ".di");
modelSet.getResources().add(diResource);
modelSet.getResources().add(view.getResource(diagramName + ".notation"));
modelSet.getResources().add(view.getResource(diagramName + ".uml"));
// Read all Model from selected file
ModelsReader modelsReader = new ModelsReader();
modelsReader.readModel(modelSet);
try {
modelSet.loadModels(diResource.getURI());
} catch (ModelMultiException e) {
// Initialize an editing domain
modelSet.getTransactionalEditingDomain();
// Copy / paste of ExportAllDiagramsEngine.initialiseServiceRegistry()
ServicesRegistry service1 = ModelSetServiceFactory.getServiceRegistry(modelSet);
try {
service1.add(MarkersMonitorService.class, 10, new MarkersMonitorService());
service1.add(CssMarkerEventManagerService.class, 10, new CssMarkerEventManagerService());
service1.add(MarkerToPseudoSelectorMappingService.class, 10, new MarkerToPseudoSelectorMappingService());
service1.add(ValidationMarkersService.class, 10, new ValidationMarkersService());
service1.add(DecorationService.class, 10, new DecorationService());
service1.startRegistry();
// Di model services
ServiceDescriptor descriptor1 = new ServiceDescriptor(DiSashModelManager.class, DiSashModelManagerServiceFactory.class.getName(), ServiceStartKind.STARTUP, 10, Collections.singletonList(TransactionalEditingDomain.class.getName()));
descriptor1.setServiceTypeKind(ServiceTypeKind.serviceFactory);
service1.add(descriptor1);
// Page Manager services
descriptor1 = new ServiceDescriptor(IPageManager.class, PageMngrServiceFactory.class.getName(), ServiceStartKind.STARTUP, 10, Collections.singletonList(DiSashModelManager.class.getName()));
ExportAllDiagramsParameter parameter = new ExportAllDiagramsParameter(modelSet);
parameter.setExportFormat(ImageFileFormat.BMP.toString());
String path = "/";
URI uri = URI.createPlatformResourceURI(path, true);
IResource outputDirectory = ResourcesPlugin.getWorkspace().getRoot().findMember(new Path(uri.toPlatformString(true)));
parameter.setOutputDirectory(outputDirectory);
parameter.setQualifiedName(true);
ExportAllDiagramsEngine exportAllDiagrams = new ExportAllDiagramsEngine();
exportAllDiagrams.initialise(parameter);
exportAllDiagrams.exportDiagramsToImages();
Unfortunately, I get exactly the same result...
Any idea what's wrong ? I'm not a GMF expert but I had a look at my model.notation and - for example - the class names that should be displayed in the diagram image are not shipped within the model.
So my understanding is that model.notation is not 'self contained'. Therefore, to get the diagram image correctly rendered, one needs to link 'model.notation' to the corresponding 'model.uml' somehow.
Hence, my previous question about the need to provide the right diagram edit part ? And, if so, how ?
Laurent
Re: How to get an image out of a Papyrus diagram ? [message #1733394 is a reply to message #1733358] |
Fri, 27 May 2016 08:34   |
Camille Letavernier Messages: 934 Registered: February 2011 |
As far as I can tell, this works fine in Papyrus. I'd say something is wrong with your resource management
In Papyrus, the ModelSet is responsible for identifying the main 3-files model (*.di, *.notation, *.uml). But, in your code, you use custom code to load these resources, before the ModelSet is actually loaded; so it probably doesn't properly register them
There is an extra plug-in for Papyrus, to integrate with CDO. Especially, this plug-in provides a "CDOAwareModelSet", I'm not familiar with this integration, but I suspect it's mandatory for Papyrus to work properly with CDO
HTH,
Camille
Camille Letavernier
Re: How to get an image out of a Papyrus diagram ? [message #1733424 is a reply to message #1733394] |
Fri, 27 May 2016 11:17   |
Member |
Hi again,
Thank you for the tip. I changed my code in order to remove my custom CDO resource loading and use CDOAwareModelSet instead :
try {
CDOAwareModelSet modelSet = new CDOAwareModelSet();
try {
ModelSetServiceFactory.setServiceRegistry(modelSet, service);
try {
modelSet.loadModels(view.getResource(diPath).getURI());
try {
String path = "/";
Good news is that the services seem to react. But I now get the following exception with the last 'service1.startRegistry()' call...
org.eclipse.papyrus.infra.core.services.ServiceMultiException: Multiple exceptions
----- exceptions : ----------
org.eclipse.papyrus.infra.core.sasheditor.contentprovider.IPageManager : Can't start DiSashModelManagerServiceFactory'. Required model (SashModel) should be loaded prior starting the service.
org.eclipse.papyrus.infra.core.sasheditor.di.contentprovider.DiSashModelManager : Can't start DiSashModelManagerServiceFactory'. Required model (SashModel) should be loaded prior starting the service.
org.eclipse.papyrus.infra.core.sasheditor.contentprovider.IPageManager : Bad state for service 'org.eclipse.papyrus.infra.core.sasheditor.contentprovider.IPageManager'. Expected 'initialized' found 'error'.
I looked at ExportAllDiagramsEngine again but I see no difference with my copy/paste.
Any idea what's wrong ? Is there maybe a dedicated algorythm used on CDO side (as for the dedicated model set) ?
Laurent
Re: How to get an image out of a Papyrus diagram ? [message #1733426 is a reply to message #1733117] |
Fri, 27 May 2016 11:51   |
I think the issue is that your ServicesRegistry is associated to your ModelSet, but not the other way round. So when your ServicesRegistry tries to find your ModelSet, it can't. In the Papyrus Tests, we use the following code:
servicesRegistry.add(ModelSet.class, 10, modelSet);
servicesRegistry.startServicesByClassKeys(ModelSet.class);
So in your case, this might look like:
try {
service.add(ModelSet.class, 10, modelSet);
service.startServicesByClassKeys(ModelSet.class);
Then the other Papyrus services depending on the ModelSet will be able to find it
HTH,
Camille
Camille Letavernier
Re: How to get an image out of a Papyrus diagram ? [message #1733604 is a reply to message #1733441] |
Mon, 30 May 2016 11:48   |
Member |
Hi again,
I keep struggling with my problem and I'm a step further.
I now get an image back where the classes and the connection names are not displayed.
Here's the new code version :
ServicesRegistry serviceRegistry = new ServicesRegistry();
serviceRegistry.add(descriptor);
try {
serviceRegistry.startRegistry();
try {
serviceRegistry.add(ModelSet.class, 11, modelSet);
serviceRegistry.startServicesByClassKeys(ModelSet.class);
ModelSetServiceFactory.setServiceRegistry(modelSet, serviceRegistry);
serviceRegistry.add(TransactionalEditingDomain.class, 11, modelSet.getTransactionalEditingDomain());
serviceRegistry.startServicesByClassKeys(TransactionalEditingDomain.class);
try {
modelSet.loadModels(view.getResource(modelPath + ".di").getURI()); //$NON-NLS-1$
serviceRegistry = ModelSetServiceFactory.getServiceRegistry(modelSet);
try {
serviceRegistry.add(MarkersMonitorService.class, 10, new MarkersMonitorService());
serviceRegistry.add(CssMarkerEventManagerService.class, 10, new CssMarkerEventManagerService());
serviceRegistry.add(MarkerToPseudoSelectorMappingService.class, 10, new MarkerToPseudoSelectorMappingService());
serviceRegistry.add(ValidationMarkersService.class, 10, new ValidationMarkersService());
serviceRegistry.add(DecorationService.class, 10, new DecorationService());
descriptor = new ServiceDescriptor(DiSashModelManager.class, DiSashModelManagerServiceFactory.class.getName(), ServiceStartKind.STARTUP, 10, Collections.singletonList(TransactionalEditingDomain.class.getName()));
// Loading the diagram from the model.notation resource
for (EObject element : view.getResource(modelPath + ".notation").getContents())
if (element instanceof Diagram) {
convertedDiagram = (Diagram) element;
modelSet.getTransactionalEditingDomain().getResourceSet().getResources().add(convertedDiagram.eResource()); // To avoid NPE at image generation
break;
// Launch conversion based on the Papyrus 'BasicEditPartProvider' declared in the plug-in extensions.
Display.getDefault().syncExec(new Runnable() {
public void run() {
diagramImage = DiagramRenderUtil.renderToSWTImage(convertedDiagram);
ByteArrayOutputStream result = new ByteArrayOutputStream();
ImageLoader imageLoader = new ImageLoader();
imageLoader.data = new ImageData[] { diagramImage.getImageData() };
imageLoader.save(result, getFormat());
diagramImage.dispose();
return new ByteArrayInputStream(result.toByteArray());
I declared the following extension in my plugin.xml which apparently makes the difference :
<extension
point="org.eclipse.gmf.runtime.diagram.ui.editpartProviders">
<editpartProvider
class="org.eclipse.papyrus.uml.diagram.common.providers.BasicEditPartProvider">
<Priority
name="Lowest">
</Priority>
</editpartProvider>
</extension>
Any idea what's still missing ?
Laurent
Re: How to get an image out of a Papyrus diagram ? [message #1733608 is a reply to message #1733604] |
Mon, 30 May 2016 12:05   |
Hi Laurent,
I think you're on the wrong track. There's definitely something wrong with the way your resources are loaded. The following lines should not be required:
break;
All further bugs are caused by this resource loading issue, so I'd suggest investigating on this rather than trying to "reinstantiate" all Papyrus providers (So all plugin.xml changes should be reverted as well).
Focus on this:
try {
After these instructions, UML and Notation resources should be present in the ModelSet, and should not be empty. If not, then something went wrong (And anything you may try after that will only be dirty workarounds, causing more problems).
However, you're trying to load CDO models, and I'm not familiar with CDO and the Papyrus integration of CDO, so I can't help you any further. All I can say is that, when the resources are properly loaded in the model set, things should work much better. You should try putitng a breakpoint on this instruction then try to understand why the resulting resources are empty:
HTH,
Camille
Camille Letavernier
Re: How to get an image out of a Papyrus diagram ? [message #1733732 is a reply to message #1733608] |
Tue, 31 May 2016 09:47   |
Member |
Hi Camille,
You are right. Since the beginning, I have problems with loading the CDO resources as they are in 'Transient' state.
I noticed that using a normal model set or a CDO aware one makes not difference.
I had a closer look to the called method. COAwareModelSet takes care of dirty resources situations and relies on a CDO export view.
In my case, I use a read-only view to load the resources from the repository. And no CDO export is involved...
Trying to cope with that CDO resources loading problem, I did override ModelSet.createResource down the calling stack to 'gently' load them.
I now get a model set with resources in a nice state.
try {
final CDOView modelSetView = view;
ModelSet modelSet = new ModelSet() {
* Properly load the cdo resources to avoid a transient state.
public Resource createResource(URI uri, String contentType) {
if (uri.scheme().compareTo("cdo") == 0) { //$NON-NLS-1$
Resource r = modelSetView.getResource(uri.path());
getResources().add(r);
return r;
} else
return super.createResource(uri, contentType);
try {
try {
modelSet.loadModels(CDOURIUtil.createResourceURI(view, modelPath + ".di")); //$NON-NLS-1$
try {
Resource diagramResource = null;
for (Resource r : modelSet.getResources())
if (r.getURI().path().compareTo(modelPath + ".notation") == 0) {
diagramResource = r;
break;
for (EObject element : diagramResource.getContents())
break;
public void run() {
But image generation still display the 'Invalid view - remove from diagram' message...
I then launched Papyrus itself in debug mode with a breakpoint after CDOAwareModelSet.loadModels() call.
I get the following resources list :
org.eclipse.papyrus.cdo.core.resource.CDOAwareModelSet@73bbf337 resources=[CDOResource@OID125("cdo.checkout://1/home/llemoux/model2.notation"), CDOResource@OID127("cdo.checkout://1/home/llemoux/model2.uml"), CDOResource@OID126("cdo.checkout://1/home/llemoux/model2.di"), org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl@62e70e74 uri='file:/C:/Users/llm/Documents/runtime-Papyrusfordebug/.metadata/.plugins/org.eclipse.papyrus.infra.core/1/home/llemoux/model2.sash']
The same action with my adapted model set gives the following result :
resources=[CDOResource@OID125("cdo://repo1/home/llemoux/model2.notation"), CDOResource@OID126("cdo://repo1/home/llemoux/model2.di"), CDOResource@OID127("cdo://repo1/home/llemoux/model2.uml"), org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl@4aa2bbce uri='file:/C:/Users/llm/Documents/runtime-BIRT.product/.metadata/.plugins/org.eclipse.papyrus.cdo.core/sashidx/home/llemoux/model2.sash']
You can see that - surprisingly - the model2.sash resource is not stored under the same plug-in...
Could this be the reason with the image is not correctly rendered ?
Laurent
Re: How to get an image out of a Papyrus diagram ? [message #1733746 is a reply to message #1733732] |
Tue, 31 May 2016 11:05   |
The *.sash model, by default, is stored in the user's workspace (It is not meant to be shared amongst users, so it's explicitly excluded from the workspace or CDO repos). So, that's not the problem.
If your resources are now properly loaded, then I would look further into the order of the instructions, and the way the ModelSet is associated to the services registry:
This will create a ModelSet when the services registry is started. Since you're providing your own ModelSet later on, these instructions should be removed
This will create a TransactionalEditingDomain for the ModelSet registered in the ServicesRegistry, as soon as the registry is started. This is required, but you need to be careful about the order (i.e. ensure your ModelSet is properly registered before the ServicesRegistry is started, so that the TransactionalEditingDomain can find it on startup)
try {
This starts all "startup" services. So your ModelSet needs to be registered before this point
return r;
} else
try {
For the reason above, this should be moved before the ServicesRegistry is started
try {
This code starts the ServicesRegistry again. Feels suspicious. These services are probably required for rendering the diagram during export, but then the registration (serviceRegistry.add(*)) should happen before the ServicesRegistry is started. The ServicesRegistry should be started only once. The last service descriptor should also be added before the ServicesRegistry is started
Camille Letavernier
[Updated on: Tue, 31 May 2016 11:05] Report message to a moderator
Re: How to get an image out of a Papyrus diagram ? [message #1733759 is a reply to message #1733746] |
Tue, 31 May 2016 13:15   |
Member |
Camille,
Here is the resulting simplified version of the code.
I followed your instructions but I had to call modelSet.loadModels before all the registering to avoid a NPE in DiSashModelManager at service startup due to the missing sash model.
return r;
} else
// Read all Models from selected source
try {
try {
// Register the model set first
serviceRegistry.add(ModelSet.class, 10, modelSet);
// Register the TED
serviceRegistry.add(TransactionalEditingDomain.class, 10, modelSet.getTransactionalEditingDomain());
ServiceDescriptor descriptor = new ServiceDescriptor(DiSashModelManager.class, DiSashModelManagerServiceFactory.class.getName(), ServiceStartKind.STARTUP, 10, Collections.singletonList(TransactionalEditingDomain.class.getName()));
try {
e.printStackTrace();
break;
break;
public void run() {
The result remains however the same
Re: How to get an image out of a Papyrus diagram ? [message #1733885 is a reply to message #1733759] |
Wed, 01 June 2016 19:46   |
Member |
Hi Camille,
I finally got the diagram generated. I was missing the Papyrus plug-ins implementing and declaring the extensions for the necessary edit parts:
org.eclipse.papyrus.uml.diagram.common;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.activity;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.clazz;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.communication;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.component;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.composite;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.deployment;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.profile;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.sequence;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.statemachine;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.timing;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.usecase;bundle-version="1.1.4",
org.eclipse.papyrus.sysml.diagram.blockdefinition;bundle-version="1.1.4",
org.eclipse.papyrus.sysml.diagram.internalblock;bundle-version="1.1.4",
org.eclipse.papyrus.sysml.diagram.parametric;bundle-version="1.1.4",
org.eclipse.papyrus.sysml.diagram.requirement;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.interactionoverview;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.stereotype.edition;bundle-version="1.1.4",
org.eclipse.papyrus.uml.diagram.symbols;bundle-version="1.1.4",
org.eclipse.papyrus.infra.gmfdiag.common;bundle-version="1.1.4",
However, there's still a difference between the generation result and what's displayed in Papyrus when opening the editor.
The background color (blue) and class symbol are missing in the generated image.
Moreover, I get the following error message:
!ENTRY org.eclipse.papyrus.infra.gmfdiag.common 4 0 2016-06-01 21:15:01.254
!MESSAGE Unexpected Error
!STACK 0
org.eclipse.papyrus.infra.core.services.ServiceNotFoundException: No service registered under 'interface org.eclipse.papyrus.infra.core.editor.IMultiDiagramEditor'
at org.eclipse.papyrus.infra.core.services.ServicesRegistry.getService(ServicesRegistry.java:408)
at org.eclipse.papyrus.infra.core.utils.AbstractServiceUtils.getService(AbstractServiceUtils.java:153)
at org.eclipse.papyrus.infra.gmfdiag.common.editpart.PapyrusDiagramEditPart.refresh(PapyrusDiagramEditPart.java:91)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer.setContents(DiagramGraphicalViewer.java:352)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at org.eclipse.gmf.runtime.diagram.ui.OffscreenEditPartFactory.createDiagramEditPart(OffscreenEditPartFactory.java:128)
at org.eclipse.gmf.runtime.diagram.ui.OffscreenEditPartFactory.createDiagramEditPart(OffscreenEditPartFactory.java:77)
at org.eclipse.gmf.runtime.diagram.ui.render.util.DiagramRenderUtil.renderToSWTImage(DiagramRenderUtil.java:79)
at org.eclipse.birt.gmf.reporting.GMFDiagramPresentationImpl$3.run(GMFDiagramPresentationImpl.java:218)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4155)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3772)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.birt.report.designer.ui.rcp.DesignerApplication.run(DesignerApplication.java:37)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
It's apparently a problem you already faced :
https://dev.eclipse.org/mhonarc/lists/mdt-papyrus.dev/msg01691.html
Is it the cause of the difference ?
Laurent
Current Time: Sat Jan 16 11:51:28 GMT 2021
Powered by FUDForum. Page generated in 0.02380 seconds
