Eclipse 4.5.2 process suspends when launching RCP with debugger [message #1732993] |
Mon, 23 May 2016 15:30 |
Bo Berney Messages: 12 Registered: July 2009 |
We have an RCP product we run in e3 compatibility mode.
Eclipse Mars.2 Release 4.5.2
Build id: 20160218-0600
Windows 7x64
JDK 1.8.0_91 x86_64
When launching our RCP application in the Eclipse debugger, the Eclipse IDE suspends (CPU shows "Suspended" in Process Explorer). When I resume it using Process Explorer, the launch never completes. If the IDE becomes responsive, then at least I can close and restart. Sometimes the IDE will hang even after resuming.
I cannot connect JVisualVM to it while it is suspended, but when it hung after resuming, I did notice that the following thread was hanging and blocking the main thread:
"Worker-4" #33 prio=5 os_prio=0 tid=0x000000001bfe6000 nid=0x5b6c runnable [0x0000000022d9e000]
java.lang.Thread.State: RUNNABLE
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(FileInputStream.java:255)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:284)
at java.io.BufferedInputStream.read(BufferedInputStream.java:345)
- locked <0x00000000d7f879f8> (a java.io.BufferedInputStream)
at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:284)
at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178)
- locked <0x00000000d7f89bf8> (a java.io.InputStreamReader)
at java.io.InputStreamReader.read(InputStreamReader.java:184)
at java.io.BufferedReader.fill(BufferedReader.java:161)
at java.io.BufferedReader.readLine(BufferedReader.java:324)
at java.io.BufferedReader.readLine(BufferedReader.java:389)
at org.eclipse.debug.internal.core.LaunchManager.cacheNativeEnvironment(LaunchManager.java:821)
at org.eclipse.debug.internal.core.LaunchManager.getNativeEnvironmentCasePreserved(LaunchManager.java:1826)
- locked <0x0000000081394628> (a org.eclipse.debug.internal.core.LaunchManager)
at org.eclipse.debug.internal.core.LaunchManager.getNativeEnvironment(LaunchManager.java:1806)
at org.eclipse.jdt.internal.launching.StandardVMDebugger.prependJREPath(StandardVMDebugger.java:422)
at org.eclipse.jdt.internal.launching.StandardVMDebugger.run(StandardVMDebugger.java:226)
at org.eclipse.pde.launching.AbstractPDELaunchConfiguration.launch(AbstractPDELaunchConfiguration.java:85)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:885)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
After resuming, the hanging launch was showing "Constructing command line..." in the Progress view.
I was able to debug fine a couple weeks ago, but somehow it is in a useless state and I cannot get it to debug at all.
Any ideas?
Attached is the complete stack trace for when it hung after resuming.
Attachment: stack.txt
(Size: 23.36KB, Downloaded 138 times)
[Updated on: Mon, 23 May 2016 08:41] Report message to a moderator
FUDForum. Page generated in 0.03536 seconds
