Home » Modeling » QVT-OML » QVTO - Import Works in 3.4 but not in 3.6
QVTO - Import Works in 3.4 but not in 3.6 [message #1732816] Fri, 20 May 2016 12:42 Go to next message
Simon Eismann is currently offline Simon EismannFriend
In my eclipse plugin project the line
import transforms.Helper;
fails when using version 3.6, but works fine on 3.4. It breaks with the msg:
Cannot find imported compilation unit 'transforms.Helper'
The file is located in a different Project which defines the following extension points in the plugin.xml:
<plugin>
    <extension point="org.eclipse.m2m.qvt.oml.runtime.qvtTransformation">
      <transformation
            file="transforms/Helper.qvto"
            id="NameHelper">
      </transformation>
      <transformation
            file="transforms/AssertHelper.qvto"
            id="AssertHelper">
      </transformation>
   </extension>
   <extension
         point="org.eclipse.m2m.qvt.oml.runtime.qvtTransformationContainer">
      <sourceContainer
            path="transforms">
      </sourceContainer>
   </extension>
</plugin>
I am using eclipse neon. There are a few threads around that describe problems with imports, but those are about Blackboxes, so i am not sure if that stuff applies. If i can supply any other files/infos to help track the error down, just let me know. I already posted this question on StackOverflow, but unfortunatly nobody there was able to help me Sad
[Updated on: Fri, 20 May 2016 05:38]
Report message to a moderator
Re: QVTO - Import Works in 3.4 but not in 3.6 [message #1732845 is a reply to message #1732816] Fri, 20 May 2016 17:54 Go to previous messageGo to next message
This is the newsgroup that the commiters monitor.
Sounds like a bug that may be a side effect of blackbox chnages. Please
raise a Bugzilla with a complete repro (zipped project(s)).
Ed Willink
> the msg:
> <plugin>
> <transformation
> id="NameHelper">
> </transformation>
> <transformation
> id="AssertHelper">
> </transformation>
> </extension>
> <extension
> <sourceContainer
> path="transforms">
> </sourceContainer>
> </extension>
> </plugin>
> help me :(
Re: QVTO - Import Works in 3.4 but not in 3.6 [message #1732882 is a reply to message #1732845] Sun, 22 May 2016 00:13 Go to previous messageGo to next message
Hello, i now got a minimum working example ready. would you mind taking a look at it before i raise a bugzilla?
http://www.filedropper.com/mwe_1
How to get it to run:
Set targetplatform (luna for it to work, neon for it to break)
Run Main.java as a junit plugin test
I'd appreciate any input on this issue
Re: QVTO - Import Works in 3.4 but not in 3.6 [message #1732895 is a reply to message #1732816] Sun, 22 May 2016 10:23 Go to previous message
Christopher Gerking is currently offline Christopher GerkingFriend
Simon Eismann wrote on Fri, 20 May 2016 08:42
[code]Cannot find imported compilation unit 'transforms.Helper'[/code
The behavior is intended. In Mars, we got rid of the restriction that the import must contain the source container ("transforms" in your case). In doing so, we align the import mechanism with workspace imports that are relative to the source container.
In your case, I suggest to change the plugin.xml declaration as follows:
      <transformation
            id="Helper">
      </transformation>
   </extension>
You can then use
import Helper;
seamlessly without any changes between development time and runtime.
For some hints on imports in QVTo, please refer to the developer guide: http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.m2m.qvt.oml.doc%2Freferences%2Fimporting.html
Previous Topic:Difference between arrow(->) and dot(.) in qvto
Next Topic:Use of quotations
Current Time: Tue Apr 16 18:03:58 GMT 2024
Powered by FUDForum. Page generated in 1.81747 seconds
