Home » Eclipse Projects » EclipseLink » LIMIT query not framed correctly when using CompositePU
LIMIT query not framed correctly when using CompositePU [message #1732467] Tue, 17 May 2016 13:57
G M is currently offline G MFriend
(The database used is MySQL in our case, not sure if the problem is reproducible with other DBs)
MySQL has a LIMIT query of the form:
SELECT ___...___ LIMIT <start>, <row_count>
In eclipselink the query is formed as below:
			String queryStr = "SELECT t FROM " + TableOne.class.getName() + " t ";
			Query query = em.createQuery(queryStr);
			query.setFirstResult(start);
			query.setMaxResults(range);
			result = query.getResultList();
When CompositePU is used consisting of one or more child persistence units, the LIMIT query is not framed correctly.
For start = 3 and range = 3:
Expected:
SELECT ___...___ LIMIT 3, 3
Query formed:
SELECT ___...___ LIMIT 3, 6
For start = 3 and range = 1:
Expected:
SELECT ___...___ LIMIT 3, 1
Query formed:
SELECT ___...___ LIMIT 3, 4
Eclipselink sets the row_count as
query.setFirstResult() + query.setMaxResults()
instead of
This issue occurs only when CompositePU is used.
Question: Could this be a bug or something we are doing wrong?
Previous Topic:The question about using fetchgraph
Next Topic:Multitenancy and History Policy not working together
Current Time: Thu Apr 25 05:39:58 GMT 2024
Powered by FUDForum. Page generated in 0.03518 seconds
