Gemini doesn't read parent classes from another bundles [message #1732417] |
Tue, 17 May 2016 07:01  |
Pavel No Messages: 47 Registered: May 2016 |
Member |
I have three bundles. In first bundle I have persistence.xml. And I have two classes : A and B. A extends B. Class A is @Entity, Class B is @MappedSuperclass.Both classes are listed in persistence.xml. Packages of the 2'dn and 3'rd bundles are exported.
If class A and class B are in the same bundle - everything ok. However, when class A in the second bundle and class B is the the third bundle I get:
WARNING: EMFProxy invocation on method createEntityManager failed: Exception: Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.6.3.v20160428-59c81c5): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: org.eclipse.gemini.jpa.classloader.CompositeClassLoader@20c0a64d
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.6.3.v20160428-59c81c5): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [myPersistenceUnit] failed.
Internal Exception: java.lang.NullPointerException
java.lang.NullPointerException: null
at org.eclipse.persistence.internal.jpa.weaving.TransformerFactory.createClassDetails(TransformerFactory.java:270)
at org.eclipse.persistence.internal.jpa.weaving.TransformerFactory.addClassDetailsForMappedSuperClasses(TransformerFactory.java:124)
at org.eclipse.persistence.internal.jpa.weaving.TransformerFactory.buildClassDetailsAndModifyProject(TransformerFactory.java:180)
at org.eclipse.persistence.internal.jpa.weaving.TransformerFactory.createTransformerAndModifyProject(TransformerFactory.java:84)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1972)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.callPredeploy(JPAInitializer.java:100)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:104)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:188)
at org.eclipse.gemini.jpa.ProviderWrapper.createEntityManagerFactory(ProviderWrapper.java:128)
at org.eclipse.gemini.jpa.proxy.EMFServiceProxyHandler.createEMF(EMFServiceProxyHandler.java:151)
at org.eclipse.gemini.jpa.proxy.EMFServiceProxyHandler.syncGetEMFAndSetIfAbsent(EMFServiceProxyHandler.java:127)
at org.eclipse.gemini.jpa.proxy.EMFServiceProxyHandler.invoke(EMFServiceProxyHandler.java:73)
at com.sun.proxy.$Proxy8.createEntityManager(Unknown Source)
When I set in persistence.xml
<property name="eclipselink.weaving" value="false"/>
I don't get any exceptions, but all fields from class B are ignored. How to solve this problem?
[Updated on: Tue, 17 May 2016 07:27] Report message to a moderator
FUDForum. Page generated in 0.01829 seconds
