Newly installed Eclipse wont create a java project. [message #1732393] |
Mon, 16 May 2016 19:12 |
Tomás Simões Messages: 1 Registered: May 2016 |
Junior Member |
Hey,
to put it in a simple way.
I just installed Eclipse for Java in Arch Linux ( 64-Bit with java 1.8.x)
I cannot create a java project..
This is the error log:
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
ava.lang.NullPointerException
at org.eclipse.swt.widgets.TabFolder.gtk_switch_page(TabFolder.java:570)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:2009)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4723)
at org.eclipse.swt.internal.gtk.OS._gtk_widget_show(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_widget_show(OS.java:14774)
at org.eclipse.swt.widgets.TabFolder.createItem(TabFolder.java:311)
at org.eclipse.swt.widgets.TabItem.createWidget(TabItem.java:123)
at org.eclipse.swt.widgets.TabItem.<init>(TabItem.java:75)
at org.eclipse.jdt.internal.ui.wizards.buildpaths.BuildPathsBlock.createControl(BuildPathsBlock.java:228)
at org.eclipse.jdt.ui.wizards.JavaCapabilityConfigurationPage.createControl(JavaCapabilityConfigurationPage.java:162)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:175)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:705)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1153)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1211)
at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1208)
at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1197)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1194)
at org.eclipse.ui.internal.dialogs.NewWizardSelectionPage.advanceToNextPageOrFinish(NewWizardSelectionPage.java:71)
at org.eclipse.ui.internal.dialogs.NewWizardNewPage$1.doubleClick(NewWizardNewPage.java:361)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:832)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:829)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1470)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1263)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:252)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:311)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1329)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction.java:115)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
eclipse.buildId=4.5.2.M20160212-1500
java.version=1.8.0_92
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=pt_PT
FUDForum. Page generated in 0.07995 seconds
