Home » Eclipse Projects » OM2M » REST API in smartM2M version
REST API in smartM2M version [message #1732319] Sun, 15 May 2016 18:42 Go to next message
Luke Tang is currently offline Luke TangFriend
https://wiki.eclipse.org/OM2M/REST_API
In "Create a description contentInstance" example:
body:
<obj>
<str name="type" val="Temperature_Sensor"/>
<str name="location" val="Home"/>
<str name="appId" val="MY_SENSOR"/>
<op name="getValue" href="gscl/applications/MY_SENSOR/containers/DATA/contentInstances/latest/content"
in="obix:Nil" out="obix:Nil" is="retrieve"/>
</obj>
What are both in and out mean?
thx
Re: REST API in smartM2M version [message #1732326 is a reply to message #1732319] Mon, 16 May 2016 01:40 Go to previous messageGo to next message
Mahdi Ben Alaya is currently offline Mahdi Ben AlayaFriend
In general, the "in" and "out" enables defining the operation contract. They can be used respectively to provide information to the user about the input and output of an operation.
For example, the "in" attribute can be used to define an obix representation to send as payload for POST request (is attribute is equal to "create" in this case)
Mahdi
[Updated on: Mon, 16 May 2016 02:59]
Report message to a moderator
Re: REST API in smartM2M version [message #1732333 is a reply to message #1732326] Mon, 16 May 2016 06:05 Go to previous message
@Mahdi Ben AlayaFriend:
Could you give me an example?
thx
Previous Topic:How many condition tags are currently supported by OM2M v1 ?
Next Topic:Use of the retargeting concept in the oneM2M version
Current Time: Tue Jan 26 00:26:51 GMT 2021
Powered by FUDForum. Page generated in 0.01413 seconds
