Home » Archived » Eclipse Process Manager (Stardust) » Unable to compile Stardust src(DOwnloaded the source, and getting compilation errors, with Java 1.8)
Unable to compile Stardust src [message #1732103] Thu, 12 May 2016 15:22 Go to next message
Aniruddha Shevade is currently offline Aniruddha ShevadeFriend
HI
This is my first time looking at stardust.
I downloaded the source, and am trying to get things compiled.
The command i use is
C:\stardust_src>mvn -e install -f product\components-pom.xml
-Dbuild.tools.home=%build.tools% -Dproduct.home=%product.home% -s %build.tools%\conf\m2\settings.xml
The error I get is shown below. Am i missing something here ?
Thanks for any help
Best Regards
Ani
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.
1:compile (default-compile) on project carnot-base: Compilation failure
[ERROR] /C:/stardust_src/engine/stardust-engine-base/src/main/
java/org/eclipse/stardust/common/config/extensions/PojoExtensionsCache.java:[88,
72] incompatible types: java.lang.Object cannot be converted to T
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal o
rg.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on p
/C:/web based clients/stardust_src/engine/stardust-engine-base/src/main/java/org
/eclipse/stardust/common/config/extensions/PojoExtensionsCache.java:[88,72] inco
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor
.java:212)
.java:153)
.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProje
ct(LifecycleModuleBuilder.java:108)
ct(LifecycleModuleBuilder.java:76)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThre
adedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(Lifecycl
eStarter.java:116)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:361)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:155)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:584)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:213)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:157)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Laun
cher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.jav
a:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(La
uncher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:
356)
Caused by: org.apache.maven.plugin.compiler.CompilationFailureException: Compila
tion failure
at org.apache.maven.plugin.compiler.AbstractCompilerMojo.execute(Abstrac
tCompilerMojo.java:858)
at org.apache.maven.plugin.compiler.CompilerMojo.execute(CompilerMojo.ja
va:129)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(Default
BuildPluginManager.java:133)
.java:208)
... 19 more
[ERROR]
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please rea
d the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureExc
eption
Re: Unable to compile Stardust src [message #1732191 is a reply to message #1732103] Fri, 13 May 2016 11:28 Go to previous message
Tanmoy Roy is currently offline Tanmoy RoyFriend
Member
Hi Ani,
Which release you have downloaded?
Btw, if your purpose is to build the Stardust war, then you can also use archetype which is straight forward.
Run below maven command to get the archetype:
mvn archetype:generate -DarchetypeGroupId=org.eclipse.stardust.deploy.jee.archet
ypes -DarchetypeArtifactId=tc7-stardust-portal-war -DarchetypeVersion=3.1.0 -DgroupId=local -DartifactId=stardust-portal-war -Dversion=3
.1.0 -DarchetypeRepository=http://download.eclipse.org/stardust/maven/releases -U
Then run
mvn clean install
this will generate the final war file in the target directory.
-Tanmoy Roy
Previous Topic:Newbie question
Next Topic:M2eclipse error 401 unauthorized
Current Time: Sun May 09 05:49:34 GMT 2021
Powered by FUDForum. Page generated in 0.01990 seconds
