Home » Eclipse Projects » Paho » Paho mqtt connection issue(Getting errors when connection)
Paho mqtt connection issue [message #1732063] Thu, 12 May 2016 11:08 Go to next message
Srinivas Pokala is currently offline Srinivas PokalaFriend
HI,
I try to create a application using paho mqtt javascript.
My config file:
http {
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream websocket {
server domain.com:8010;
server {
listen 8020;
location / {
proxy_pass http://websocket;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
server {
listen 80;
server_name domain.com ;
server_tokens off;
location /websocket {
code:
var client = new Paho.MQTT.Client("ws://domain.com/websocket", "myClientId" + new Date().getTime());
Please find attached file
  • Attachment: mqtt.png
    (Size: 78.96KB, Downloaded 367 times)
  • Attachment: mqtt1.png
    (Size: 70.67KB, Downloaded 175 times)
Re: Paho mqtt connection issue [message #1732102 is a reply to message #1732063] Thu, 12 May 2016 15:22 Go to previous message
James Sutton is currently offline James SuttonFriend
Member
Just spotted this, Same issue raised and answered here: https://github.com/eclipse/paho.mqtt.javascript/issues/71
Previous Topic:Publish message from callback messageArrived()
Next Topic:Paho: Durable Producer
Current Time: Fri Dec 04 03:01:58 GMT 2020
Powered by FUDForum. Page generated in 0.01894 seconds
