How restrict only one edge between nodes [message #1731786] |
Tue, 10 May 2016 07:35 |
Martin Jedlicka Messages: 122 Registered: January 2016 |
I had a question, how Sirius restrict (set, defined) only one edge node.
The grammar is defined that the number of edges (Transition) from the node StartProcess may be only one, as shown below.
StartProcess:
{StartProcess} 'Start' name=EString
'code' code=EString
('description' description=EString)?
'component' component=EString
'type' type=ElementType
(transitions=Transition)?
When the Sirius make the first edge node StartProcess and edge is created. When I do the node StartProcess another edge, and displays an exception, see below.
!MESSAGE Impossible to add a value to the reference transitions of the object com.ge.eufo.processDesigner.impl.StartProcessImpl@787480 (name: START_1, code: START_1, description: Start_1, type: ProcessStart) (component: START_1)
!STACK 0
java.lang.RuntimeException
at org.eclipse.sirius.business.internal.helper.task.operations.CreateInstanceTask.execute(CreateInstanceTask.java:93)
at org.eclipse.sirius.business.internal.helper.task.ExecuteToolOperationTask.executeTask(ExecuteToolOperationTask.java:106)
at org.eclipse.sirius.business.internal.helper.task.ExecuteToolOperationTask.executeTask(ExecuteToolOperationTask.java:117)
at org.eclipse.sirius.business.internal.helper.task.ExecuteToolOperationTask.execute(ExecuteToolOperationTask.java:90)
at org.eclipse.sirius.business.api.helper.task.TaskExecutor.execute(TaskExecutor.java:64)
at org.eclipse.sirius.tools.api.command.SiriusCommand.doExecute(SiriusCommand.java:80)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.sirius.diagram.ui.tools.api.command.GMFCommandWrapper.doExecuteWithResult(GMFCommandWrapper.java:102)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:134)
at org.eclipse.sirius.diagram.ui.tools.internal.commands.WrappingCommandIgnoringAffectedFiles.execute(WrappingCommandIgnoringAffectedFiles.java:124)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:516)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:71)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:52)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:156)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTool.java:425)
at org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(AbstractTool.java:438)
at org.eclipse.gef.tools.AbstractConnectionCreationTool.handleCreateConnection(AbstractConnectionCreationTool.java:256)
at org.eclipse.gef.tools.ConnectionCreationTool.handleButtonDown(ConnectionCreationTool.java:77)
at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.java:1091)
at org.eclipse.gef.EditDomain.mouseDown(EditDomain.java:245)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMousePressed(DomainEventDispatcher.java:348)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown(LightweightSystem.java:523)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:192)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Martin
Re: How restrict only one edge between nodes [message #1731928 is a reply to message #1731927] |
Wed, 11 May 2016 07:22 |
Hi Martin,
Starting from your grammar it seems that the transitions feature should
contain maximum one Transition. In your creation tool you should make
sure that the createInstance can be invoked safely. The precondition
expression should check that the StartProcess doesn't already have a
transition. In your case you should have a Connection Start Precondition
that uses the preSource variable (the StartProcess).
On 05/11/2016 09:07 AM, Martin Jedlicka wrote:
> You can solve it using Precondition Expression on the edge?
> If so, how?
> Martin
Florian - Obeo
FUDForum. Page generated in 0.03820 seconds
