Home » Eclipse Projects » Eclipse 4 » Checking if a part inside of a PartStack was closed by pressing the close icon in the tab.
Checking if a part inside of a PartStack was closed by pressing the close icon in the tab. [message #1731676] Mon, 09 May 2016 08:15 Go to next message
Niklas Schulze is currently offline Niklas SchulzeFriend
Platform: WIndows 8.1 Pro
Parts in my PartStack are currently being closed in two ways.
1. By pressing the close icon on the corresponding tab.
2. By reloading the entire PartStack. (custom method, uses EPartService.hidePart())
I'm working on caching peviously opened parts to reopen then when the PartStack is reloaded. But I also need to remove them from the cache when the part is closed by pressing the close icon.
Is there an event or something similar to catch the pressing of the close icon?
Thanks for your help.
Edit:
Can be closed.
I used my problem by using tags.
[Updated on: Thu, 12 May 2016 08:41]
Report message to a moderator
Re: Checking if a part inside of a PartStack was closed by pressing the close icon in the tab. [message #1734361 is a reply to message #1731676] Tue, 07 June 2016 13:40 Go to previous message
Piero Campalani is currently offline Piero CampalaniFriend
Hey.. how exactly did you use tags to solve this issue?
*thanks* !
Previous Topic:Pre-Shutdown hooks
Next Topic:Export RCP don't work
Current Time: Tue Aug 16 05:13:04 GMT 2022
Powered by FUDForum. Page generated in 0.01919 seconds
