Home » Modeling » TMF (Xtext) » How to Contribute (Need help in setting up the Xtext dev env.)
How to Contribute [message #1731606] Sat, 07 May 2016 18:54 Go to next message
Neeraj Bhusare is currently offline Neeraj BhusareFriend
I am trying to setup the Xtext dev. environment on my machine. I tried the steps mentioned under the section "How to contribute" [0]. The provisioning works fine, the code gets checked out, however I see a lot of errors in the projects [1]. The same happens if I provision the Xtext DSL Tools product.
Am I missing something here ??? Would be great if I could get some help. Tx in advance.
[0] https://github.com/eclipse/xtext/blob/master/README.md#how-to-contribute
[1] https://raw.githubusercontent.com/nbhusare/Xtext-sandbox/master/Project-errors
Twitter : @NeerajBhusare
Blog : https://nbhusare.github.io/
Best regards, Neeraj
Re: How to Contribute [message #1731622 is a reply to message #1731606] Sun, 08 May 2016 06:38 Go to previous messageGo to next message
Uli Merkel is currently offline Uli MerkelFriend
Due to license reasons, the ANTLR part is downloaded when you run the MWE the very first time (you have to enter "Y" to get the job done).
AFAIK this will do the job.
Re: How to Contribute [message #1731623 is a reply to message #1731606] Sun, 08 May 2016 07:04 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Which Java version do you use
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: How to Contribute [message #1731642 is a reply to message #1731623] Sun, 08 May 2016 17:19 Go to previous message
@Uli Merkel - Let me try .
@Christian Dietrich - I am using Java 7.
Previous Topic:Type for variable
Next Topic:Custom project creation
Current Time: Tue Oct 20 07:33:36 GMT 2020
Powered by FUDForum. Page generated in 0.01772 seconds
