Home » Eclipse Projects » Sirius » Type/Style/Class not found during VSM validation
Type/Style/Class not found during VSM validation [message #1731542] Fri, 06 May 2016 11:49 Go to next message
Hi there!
I'm just trying to get started with Sirius and seem to have a gap in my configuration somewhere. For each class [CLASS] that I'm trying to use from my eCore model I'm getting a set of errors during the VSM validation:
*) A style is missing for [CLASS]
*) Invalid type: bi_repository.[CLASS]
*) The Class bi_repository.[CLASS] does not exist
The eCore model file is located in another project and registered with the Modeling Project using a project dependency. The Domain Class references are specified by using the "bi_repository.[CLASS]" notation. These were taken from the references offered by the auto completion mechanism.
I'm using Sirius version 3.1.6 on Mars.2 Release 4.5.2.
What I am doing wrong? Thanks a lot! I appreciate your help!
[Updated on: Fri, 06 May 2016 11:53] by Moderator
Re: Type/Style/Class not found during VSM validation [message #1731789 is a reply to message #1731542] Tue, 10 May 2016 03:46 Go to previous messageGo to next message
On 05/06/2016 05:49 PM, Marcus Rickert wrote:
> Hi there!
Have you deployed your metamodel plugins in your environment?
If you are a beginner with Sirius you can take a look on the get started
page here: https://eclipse.org/sirius/getstarted.html
> mechanism.
Florian - Obeo
Re: Type/Style/Class not found during VSM validation [message #1733780 is a reply to message #1731789] Tue, 31 May 2016 13:04 Go to previous message
Hi Florian,
thanks for your answer. I followed the tutorial and it worked fine. However, for my own domain specific model (given as ecore model) I do not have a populated model yet to play with. That's is why I would like to create the editor in the first place. Apparently, the Eclipse/Sirius sample model contains more than just the class instances of the domain specific model but also some kind of implementation of the model elements (e.h. a Man or a Woman). How do I get/create/generate these implementations if I start from scratch? Thanks a lot!
Warm Regards,
Marcus
Previous Topic:Delete relation in model if source/target node is deleted
Next Topic:WorkspaceImage customisation does not aut-rotate when bordered node is moved
Current Time: Fri Apr 18 13:39:17 EDT 2025
Powered by FUDForum. Page generated in 0.03108 seconds
