Eclipse Plugin Install Error [message #1731273] |
Wed, 04 May 2016 06:26 |
RamaRao Nandamuri Messages: 120 Registered: April 2016 |
Hi Christian,
I have created plugin for my dsl editor that developed using xtext.
It is installing on my eclipse IDE successfully but when I using the same plugin on some other system it is throwing below error. I debug the plugin but I didn't get the solution.
I checked in my plugin it contains all the artifacts like :
Please find the attached plugin. Could you please tell me the bug in my setup?
[Updated on: Wed, 04 May 2016 09:35] Report message to a moderator
Re: Eclipse Plugin Install Error [message #1731294 is a reply to message #1731291] |
Wed, 04 May 2016 07:37 |
xtext has parts that generate stuff, but xtext has api parts as well.
these api parts are not copied to each language but reused by all languages.
this is why you need e.g. the plugin org.eclipse.xtext in your target environment.
of couse you can e.g. add the xtext.sdk feature to the included features in the feature editor of your feature xml
or you simply add the xtext update site as well to your customer ide.
or .... (tons of options on how to deal with this)
Twitter : @chrdietrich
FUDForum. Page generated in 0.04945 seconds
