Home » Eclipse Projects » EclipseLink » Entity automatically getting Detached and failing on insert for integrity constrain(Entity automatically getting Detached and failing on insert for integrity constrain)
Entity automatically getting Detached and failing on insert for integrity constrain [message #1731267] Wed, 04 May 2016 04:58
Prashant Saraf is currently offline Prashant SarafFriend
Same Topic is also posted on
http://stackoverflow.com/questions/37018740/eclipselink-detaching-entity-and-performing-insert-for-existing-entity
I have following M-M relationship scenario
Employee and Project are connected with each other by EmployeeProjectRlsp
I have below Relationship defined
In Employee
@OneToMany(mappedBy = "employee", cascade = { CascadeType.PERSIST, CascadeType.MERGE })
private List<EmployeeProjectRlsp> employeeProjectRlsp;
In Project
@OneToMany(mappedBy = "project", cascade = { CascadeType.PERSIST, CascadeType.MERGE })
In EmployeeProjectRlsp
// bi-directional many-to-one association to Agreement
@ManyToOne(cascade = { CascadeType.PERSIST, CascadeType.MERGE })
@JoinColumn(name = "EMPLOYEE_ID", nullable = false)
private Employee employee;
// bi-directional many-to-one association to Category
@JoinColumn(name = "PROJECT_ID", nullable = false)
private Project project;
Now issue : We are doing persist for each employee we have everything as cascade. Here requirement is if Project is not there in DB then create new Project
Coding is doing something like below
Project dbProject = projectDAO.getProject(xmlProject);
if(dbProject != null)
xmlProject = dbProject;
EmployeeProjectRlsp employeeProjectRlsp = emproRlspFactory.getEmployeeProjectRlsp(xmlProject, xmlEmployee);
xmlEmploye.setEmployeeProjectRlsp(employeeProjectRlsp);
employeDao.persist(xmlEmploye);
when I run above code in single thread environment everything works fine. when I am having 100 thread coming in same time I am getting integrity constrain on Project Object where project is saved days back.
I have all the Entities and their relationship marked with cascade
Now this issue of integrity constrain coming to any of existing object coming from DB by either egar/lezy fetch or DAO call its keep failing at random places.
Can someone help me here what need to be done.
Previous Topic:CacheCoordination with synchronization type INVALIDATE_CHANGED_OBJECTS issues
Next Topic:[moxy] Marshalling empty collection as absent elements for XML
Current Time: Wed Apr 21 01:50:36 GMT 2021
Powered by FUDForum. Page generated in 0.01312 seconds
