Home » Modeling » VIATRA » execute the demo(problem running library headless example)
execute the demo [message #1731191] Tue, 03 May 2016 12:26 Go to next message
Sven Uthe is currently offline Sven UtheFriend
Setup:
viatra 1.2 from release repo
(no xcore integration found)
added example repo
Eclipse Configuration:
Toggle Spoiler
Problem:
I tried to execute the demo.
I could not get headless demo running.
library.xvql in project library.domain.base does not generate code.
viatra-derived -> A generic type in this context must refer to a classifier or a type parameter
All the references to old versions in the documentation are confusing me.
My long term plan is to develop a visual language to define generic rules for a model.
Re: execute the demo [message #1731205 is a reply to message #1731191] Tue, 03 May 2016 14:11 Go to previous message
Abel Hegedus is currently offline Abel HegedusFriend
Hi Sven,
first of all, thanks for trying out VIATRA.
Which "demo" are you trying to execute? We recommend using the tutorial: http://static.incquerylabs.com/projects/viatra/viatra-docs/ViatraDocs.html
We do not ship the Xcore integration in 1.2.0, if you need it for some reason, I can describe how to get it up and running from source.
For the headless example, check out the wiki page: https://wiki.eclipse.org/VIATRA/Query/UserDocumentation/HeadlessExecution
Can you give us an example for the "references to old versions"?
As you can see from https://wiki.eclipse.org/VIATRA/History VIATRA has a long history and we try to make documentation accessible for earlier versions. However, we welcome suggestions on how to do this better.
Cheers
Previous Topic:Queries against xtext-dsl
Next Topic:How should VIATRA be incorporated into an existing application
Current Time: Wed Aug 12 16:30:42 GMT 2020
Powered by FUDForum. Page generated in 0.01808 seconds
