Home » Modeling » TMF (Xtext) » Showing error on run time application(Showing error on run time application)
Showing error on run time application [message #1731182] Tue, 03 May 2016 11:27 Go to next message
RamaRao Nandamuri is currently offline RamaRao NandamuriFriend
Hi Christian,
Please find the attached images.
(1) is my xtext project it contains all the code.
When I run the application it is showing errors on the xtext project console
(2) is the feature project I have created for my xtext project
(3) is the project created to test my dsl editor after installing the plugin I have generated from (2).
After installing the plugin I want to show the error on newly created project console.
  • Attachment: projects.png
    (Size: 29.86KB, Downloaded 91 times)
  • Attachment: window.png
    (Size: 245.07KB, Downloaded 88 times)
  • Attachment: error.png
    (Size: 242.59KB, Downloaded 87 times)
Re: Showing error on run time application [message #1731183 is a reply to message #1731182] Tue, 03 May 2016 11:28 Go to previous messageGo to next message
Re: Showing error on run time application [message #1731184 is a reply to message #1731183] Tue, 03 May 2016 11:30 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
then you should not do sysout but should inform how to log into eclipse console. (this is NOT xtext related)
but this will be redundant, since the error is already in the problems view (xtext does this automatically for you)
Twitter : @chrdietrich
Re: Showing error on run time application [message #1731188 is a reply to message #1731184] Tue, 03 May 2016 12:09 Go to previous messageGo to next message
Sorry I don't understand
Re: Showing error on run time application [message #1731190 is a reply to message #1731188] Tue, 03 May 2016 12:14 Go to previous messageGo to next message
windows -> show view -> problems
Re: Showing error on run time application [message #1731192 is a reply to message #1731190] Tue, 03 May 2016 12:28 Go to previous messageGo to next message
https://wiki.eclipse.org/FAQ_How_do_I_write_to_the_console_from_a_plug-in%3F
Re: Showing error on run time application [message #1731193 is a reply to message #1731192] Tue, 03 May 2016 12:31 Go to previous messageGo to next message
yes
Re: Showing error on run time application [message #1731197 is a reply to message #1731193] Tue, 03 May 2016 13:26 Go to previous messageGo to next message
Hi Christian,
Could you please tell me how to add dependency in plugin.xml for org.eclipse.ui.console?
Re: Showing error on run time application [message #1731198 is a reply to message #1731197] Tue, 03 May 2016 13:30 Go to previous messageGo to next message
hi Christian,
I got it...
Re: Showing error on run time application [message #1731211 is a reply to message #1731198] Tue, 03 May 2016 14:51 Go to previous messageGo to next message
Hi Christian,
Do you have any example to eclipse plugin write message to console
Re: Showing error on run time application [message #1731213 is a reply to message #1731211] Tue, 03 May 2016 14:58 Go to previous message
No
Previous Topic:How to bind AbstractInternalAntlrParser
Next Topic:What is the best way to allow xtext work on extensions ignoring case of them
Current Time: Tue Apr 16 13:54:03 GMT 2024
Powered by FUDForum. Page generated in 0.95405 seconds
