Home » Modeling » TMF (Xtext) » Packaging xtext project(Packaging xtext project)
Packaging xtext project [message #1731054] Mon, 02 May 2016 15:00 Go to next message
RamaRao Nandamuri is currently offline RamaRao NandamuriFriend
I have done with my xtext project. Now I want to package my xtext project as plugin and make it available to my customers that they can download and install the plugin from server.
Can anyone explain what are the steps I need to perform?
Re: Packaging xtext project [message #1731056 is a reply to message #1731054] Mon, 02 May 2016 15:02 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
do you use a build system like maven? if not
- create a new feature project
- add your plugins to the feature
- use the export -> deployable features wizard
Twitter : @chrdietrich
Re: Packaging xtext project [message #1731059 is a reply to message #1731054] Mon, 02 May 2016 15:06 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
On 02/05/2016 17:00, RamaRao Nandamuri wrote:
you may also want to have a look at this thread
https://www.eclipse.org/forums/index.php/t/1076761/
Prof. Lorenzo Bettini, Computer Science, DISIA, Univ. Firenze
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Packaging xtext project [message #1731072 is a reply to message #1731056] Mon, 02 May 2016 17:04 Go to previous messageGo to next message
Hi Christian,
I have created feature project it generated feature.xml and build.properties files.
Now I right click on that generated plugin and exported that project.
But when I am trying to install that using eclipse new software install options in help menu but it is showing an error like no project exists to install.
After export it created a folder with all jars.
What I have to do now?
Re: Packaging xtext project [message #1731077 is a reply to message #1731072] Mon, 02 May 2016 17:12 Go to previous messageGo to next message
Did you deselect the categorize item when installing. What is the error you
get
Re: Packaging xtext project [message #1731079 is a reply to message #1731077] Mon, 02 May 2016 17:29 Go to previous messageGo to next message
Hi Christian,
I didn't see any option like categorize item.
I am getting error : No repository found
Re: Packaging xtext project [message #1731080 is a reply to message #1731079] Mon, 02 May 2016 17:31 Go to previous messageGo to next message
are you shure you added the correct reprository and correctly do the export
please describe step by step what you do
Re: Packaging xtext project [message #1731081 is a reply to message #1731080] Mon, 02 May 2016 17:36 Go to previous messageGo to next message
Steps I followed:
New -> Project -> Plugin -in Development -> Feature Project and selected all xtext related projects.
Then it generate project with only two files : build.properties and feature.xml
Next: right click on feature.xml -> Export -> Deployable Features -> Select available features and Archive file option. Thats all I did. It generated zip file.
Next: Went to eclipse help menu-> install new software. Then I got no repository error
Re: Packaging xtext project [message #1731084 is a reply to message #1731081] Mon, 02 May 2016 17:45 Go to previous messageGo to next message
did you add your plugin to feature.xml?
Re: Packaging xtext project [message #1731086 is a reply to message #1731084] Mon, 02 May 2016 17:46 Go to previous messageGo to next message
yes I did.
Re: Packaging xtext project [message #1731089 is a reply to message #1731086] Mon, 02 May 2016 17:56 Go to previous messageGo to next message
and it does not work?
can you share the folder / zip created?
Re: Packaging xtext project [message #1731090 is a reply to message #1731086] Mon, 02 May 2016 17:57 Go to previous messageGo to next message
Can I use apache maven for build
Re: Packaging xtext project [message #1731091 is a reply to message #1731089] Mon, 02 May 2016 17:58 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 02 May 2016 18:04]
Report message to a moderator
Re: Packaging xtext project [message #1731092 is a reply to message #1731091] Mon, 02 May 2016 18:01 Go to previous messageGo to next message
if i delesect "group items by catorgory" then i get your stuff.
you can add a category.xml as well and select it during export
Re: Packaging xtext project [message #1731093 is a reply to message #1731092] Mon, 02 May 2016 18:03 Go to previous messageGo to next message
Can you tell the steps I need to do?
Re: Packaging xtext project [message #1731094 is a reply to message #1731093] Mon, 02 May 2016 18:05 Go to previous messageGo to next message
take this category.xml
https://gitlab.com/cdietrich/xtext-maven-example/blob/master/org.xtext.example.demodsl.p2repo/category.xml
replace the feature name with yours.
in the export dialog on the options page there is a box to select the category.xml
Re: Packaging xtext project [message #1731095 is a reply to message #1731094] Mon, 02 May 2016 18:12 Go to previous messageGo to next message
<site>
<feature url="features/org.xtext.example.demodsl.sdk_1.0.0.qualifier.jar" id="com.prolifics.JPLEditor" version="1.0.0.qualifier">
<category name="com.prolifics.jpl.JPLEditor"/>
</feature>
<category-def name="com.prolifics.jpl.JPLEditor" label="JPL Editor"/>
</site>
I have added category name with my What about feature url ?
Re: Packaging xtext project [message #1731096 is a reply to message #1731095] Mon, 02 May 2016 18:13 Go to previous messageGo to next message
Simply open it with the category editor and hit the add button there
Re: Packaging xtext project [message #1731097 is a reply to message #1731096] Mon, 02 May 2016 18:16 Go to previous messageGo to next message
Yeah its working. Why it is asking for git username and password? Can I skip that?
Re: Packaging xtext project [message #1731098 is a reply to message #1731097] Mon, 02 May 2016 18:16 Go to previous messageGo to next message
It should not be asking. Are you sure that is related?
Re: Packaging xtext project [message #1731099 is a reply to message #1731098] Mon, 02 May 2016 18:25 Go to previous message
No it is not related
Previous Topic:Showing error on run time application
Next Topic:eliminating left recursion
Current Time: Tue Apr 16 05:48:21 GMT 2024
Powered by FUDForum. Page generated in 0.07276 seconds
