Re: Providing type for keywords [message #1731065 is a reply to message #1731064] |
Mon, 02 May 2016 16:03   |
i mean something like
package org.example.smalljava.typing
import com.google.common.base.Predicates
import com.google.inject.Inject
import org.eclipse.emf.ecore.EObject
import org.eclipse.emf.ecore.EcoreFactory
import org.eclipse.xtext.naming.QualifiedName
import org.eclipse.xtext.scoping.IGlobalScopeProvider
import org.example.smalljava.lib.SmallJavaLib
import org.example.smalljava.smallJava.SJAssignment
import org.example.smalljava.smallJava.SJBoolConstant
import org.example.smalljava.smallJava.SJClass
import org.example.smalljava.smallJava.SJExpression
import org.example.smalljava.smallJava.SJHere
import org.example.smalljava.smallJava.SJIntConstant
import org.example.smalljava.smallJava.SJMemberSelection
import org.example.smalljava.smallJava.SJMethod
import org.example.smalljava.smallJava.SJNew
import org.example.smalljava.smallJava.SJNull
import org.example.smalljava.smallJava.SJReturn
import org.example.smalljava.smallJava.SJStringConstant
import org.example.smalljava.smallJava.SJSuper
import org.example.smalljava.smallJava.SJSymbolRef
import org.example.smalljava.smallJava.SJThis
import org.example.smalljava.smallJava.SJVariableDeclaration
import org.example.smalljava.smallJava.SmallJavaFactory
import org.example.smalljava.smallJava.SmallJavaPackage
import static extension org.example.smalljava.util.SmallJavaModelUtil.*
import org.eclipse.emf.ecore.util.EcoreUtil
class SmallJavaTypeProvider {
@Inject extension SmallJavaLib
@Inject IGlobalScopeProvider globalScopeProvider
val ep = SmallJavaPackage::eINSTANCE
public static val stringType =
SmallJavaFactory::eINSTANCE.createSJClass => [name = 'stringType']
public static val intType =
SmallJavaFactory::eINSTANCE.createSJClass => [name = 'intType']
public static val booleanType =
SmallJavaFactory::eINSTANCE.createSJClass => [name = 'booleanType']
public static val nullType =
SmallJavaFactory::eINSTANCE.createSJClass => [name = 'nullType']
def typeFor(SJExpression e) {
switch (e) {
SJThis : e.containingClass
SJHere : e.here
SJSuper : e.containingClass.getSuperclassOrObject
SJSymbolRef: e.symbol?.type
SJNew: e.type
SJMemberSelection: e.member?.type
SJNull: nullType
SJStringConstant: stringType
SJIntConstant: intType
SJBoolConstant: booleanType
def SJClass getHere(EObject e) {
var result = globalScopeProvider.getScope(e.eResource, EcoreFactory.eINSTANCE.createEReference => [EType = SmallJavaPackage.Literals.SJ_CLASS] , Predicates.alwaysTrue).getSingleElement(QualifiedName.create("Here")).EObjectOrProxy as SJClass
return EcoreUtil.resolve(result, e.eResource.resourceSet) as SJClass
def expectedType(SJExpression e) {
val c = e.eContainer
val f = e.eContainingFeature
switch (c) {
SJVariableDeclaration case f == ep.SJVariableDeclaration_Expression :
c.type
SJAssignment case f == ep.SJAssignment_Right :
c.left.typeFor
SJReturn case f == ep.SJReturn_Expression :
c.containingMethod.type
SJMemberSelection case f == ep.SJMemberSelection_Args : {
// assume that it refers to a method and that there
// is a parameter corresponding to the argument
try {
(c.member as SJMethod).params.get(c.args.indexOf(e)).type
} catch (Throwable t) {
null // otherwise there is no specific expected type
case f == ep.SJIfStatement_Expression: booleanType
def argsTypesAsStrings(SJMemberSelection sel) {
"(" + sel.args.map[typeFor?.name].join(", ") + ")"
def isPrimitive(SJClass c) {
c.eResource == null
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
FUDForum. Page generated in 0.02783 seconds
