Home » Modeling » TMF (Xtext) » Project Wizard for xtext Project(How to generate project wizard using xtext?)
Project Wizard for xtext Project [message #1731030] Mon, 02 May 2016 11:46 Go to next message
Han Li Koay is currently offline Han Li KoayFriend
Hi guys!
May i know how do i configure my mwe2 workflow to generate the project wizard automatically for me for xtext 2.9.2? I realized that the workflow changed from the old Xtext version and i did not know how exactly should I configure the wizard fragments for the latest Xtext version.
And previously when i try to create my DSL project using the custom project wizard, it was found in the "Xtext" folder which looks like this:
http://s32.postimg.org/z05nj1k9x/xtext.png
I was hoping to get a project wizard structure like this that has its own individual folder which is not under Xtext folder:
- Xtext
-- Xtext Project
- UPF Editor
-- UPF Editor file
-- UPF Editor project
Is there any way to achieve something like that in xtext project?
Any help is appreciated greatly!
Hanli Smile
Re: Project Wizard for xtext Project [message #1731032 is a reply to message #1731030] Mon, 02 May 2016 12:02 Go to previous messageGo to next message
Christian Dietrich is currently online Christian DietrichFriend
you may follow https://bugs.eclipse.org/bugs/show_bug.cgi?id=490796.
did you try to use as workaround
fragment = org.eclipse.xtext.generator.adapter.FragmentAdapter {
fragment = org.eclipse.xtext.ui.generator.projectWizard.SimpleProjectWizardFragment {} //from .... xtext.generator
Twitter : @chrdietrich
Re: Project Wizard for xtext Project [message #1731035 is a reply to message #1731032] Mon, 02 May 2016 12:41 Go to previous messageGo to next message
Sorry Christian, but that link is broken.
But i successfully generated the project wizard by using:
fragment = ui.projectWizard.SimpleProjectWizardFragment2{
generate = true
Do you have any idea on the 2nd question of my first post?
Hanli Smile
Re: Project Wizard for xtext Project [message #1731044 is a reply to message #1731035] Mon, 02 May 2016 13:11 Go to previous messageGo to next message
well it seems to be the . https://bugs.eclipse.org/bugs/show_bug.cgi?id=490796
have a look the the generated plugin.xml / plugin.xml_gen (you may have to merge the second to the first) - i am sure it puts the wizard to a certain category
Re: Project Wizard for xtext Project [message #1731063 is a reply to message #1731044] Mon, 02 May 2016 15:14 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
As Christian said, this is now available, but in Xtext 2.10 nightly.
The documentation has also been updated, you can see the diff here:
https://github.com/eclipse/xtext/pull/989/files
The project wizard will be by default in the "Xtext" category as it also
used to be in the past.
cheers
Lorenzo
Prof. Lorenzo Bettini, Computer Science, DISIA, Univ. Firenze
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Project Wizard for xtext Project [message #1731124 is a reply to message #1731063] Tue, 03 May 2016 03:03 Go to previous messageGo to next message
Thanks Christian and Lorenzo for the help.
I defined my own category and changed the default "Xtext" category to my custom category in plugin.xml and it works perfectly.
Is there any default icon that i can set to the project wizard?
Hanli Smile
Re: Project Wizard for xtext Project [message #1731126 is a reply to message #1731124] Tue, 03 May 2016 03:09 Go to previous message
http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fdialogs_wizards_newWizards.htm
Previous Topic:Providing type for keywords
Next Topic:How to resolve reference to ecore class?
Current Time: Tue Apr 16 13:04:01 GMT 2024
Powered by FUDForum. Page generated in 0.16638 seconds
