Home » Eclipse Projects » EGit / JGit » EGit is showing 401: Unauthorized error when pushing to TFS Git repository(For Small amount of files pushing is success. For more amount of files 401 error is showing.)
EGit is showing 401: Unauthorized error when pushing to TFS Git repository [message #1730642] Wed, 27 April 2016 10:19 Go to next message
rbv venkat is currently offline rbv venkatFriend
Environment:
IDE : Eclispe Luna , EGit 3.4.2
Remote Git repository configured in TFS server.
Local repository is successfully created using http protocol.
When pushing some selected files (size < 500 KB) to remote repository, operation is completed with out any error.
Remote repository is showing checked in files too.
When trying to push set of files( > 500 KB) to remote repository, below error is showing.
http://tfs.xxxxxxxx : 401 Unauthorized.
When I see the eclipse error log. It is showing below error.
An exception occurred during push on URI http://xxxxxxxx : 401 Unauthorized
org.eclipse.jgit.api.errors.TransportException: http://xxxxxxx: 401 Unauthorized
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:160)
at org.eclipse.egit.core.op.PushOperation.run(PushOperation.java:228)
at org.eclipse.egit.ui.internal.push.PushOperationUI.execute(PushOperationUI.java:167)
at org.eclipse.egit.ui.internal.push.PushOperationUI$1.run(PushOperationUI.java:229)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.jgit.errors.TransportException: http://xxxxxxxx: 401 Unauthorized
at org.eclipse.jgit.transport.TransportHttp$Service.openResponse(TransportHttp.java:876)
at org.eclipse.jgit.transport.TransportHttp$MultiRequestService.execute(TransportHttp.java:978)
at org.eclipse.jgit.transport.TransportHttp$Service$HttpExecuteStream.read(TransportHttp.java:904)
Can you please help on this issue?
Re: EGit is showing 401: Unauthorized error when pushing to TFS Git repository [message #1731367 is a reply to message #1730642] Wed, 04 May 2016 16:14 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
you are using a pretty ancient EGit version, you should consider to upgrade
This doesn't look like an EGit problem, if the server says you aren't authorized what should EGit do about that ?
Talk to your server's administrator to check why you can't authenticate.
Previous Topic:Calculate file path to local GIT repository with EGit
Next Topic:Git Import = General Project & Can't run as java
Current Time: Mon Feb 17 07:04:34 GMT 2020
Powered by FUDForum. Page generated in 0.03303 seconds
