Re: [PyDev] win32com ImportError: DLL load failed [message #1730538 is a reply to message #1730463] |
Tue, 26 April 2016 14:43 |
On 04/25/2016 10:02 PM, Andrew Yang wrote:
> Hello,
> I just installed win32com for Python and it's working well in IDLE, that
> is, I can import win32com without any problem. But in Eclipse, I always
> get this error message as follows.
> import win32com.client as win32
> File "C:\Python27\Lib\site-packages\win32com\__init__.py", line 5, in
> <module>
> import win32api, sys, os
> ImportError: DLL load failed: The specified module could not be found.
> I tried to get rid of Python as an interpreter and then added it again
> which also added PYTHONPATH automatically. But it didn't work. The only
> way to get it work was to change the working directory before importing
> win32com module as follows. Isn't there any smarter way than this to
> resolve the problem?
> import os
> #os.chdir("C:\\Python27")
Please understand that Python is not a language supported directly by
Eclipse in these forums. It's done by third party (the PyDev guy) and
you'll need to establish support a different way than through this
forum. Take a look around http://www.pydev.org and also consider
stackoverflow.com with the PyDev and Python tags.
Cheers and best of luck to you.
FUDForum. Page generated in 0.03428 seconds
