shell - can't drive initial size [message #1729786] |
Tue, 19 April 2016 06:06  |
Frank Bergemann Messages: 6 Registered: June 2010 |
I am using eclipse 4.4.2 with WindowBuilder to create a mini GUI.
But i can't make the initial Form show up with proper size.
Here's is a demo cut back to the essentials:
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.swt.widgets.MenuItem;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
public class TestGui {
private Display _display;
private Shell _shell;
private Composite _composite;
private Button _btnRun;
public TestGui()
_display = new Display();
_shell = new Shell(_display);
_shell.setSize(283, 275);
initUI(_shell);
private void initUI(Shell shell) {
shell.setLayout(new GridLayout(1, true));
_composite = new Composite(shell, SWT.CENTER);
_composite.setLayoutData(new GridData(SWT.FILL, SWT.BEGINNING, true, true));
shell.layout();
Menu menuBar = new Menu(shell, SWT.BAR);
MenuItem menuItem = new MenuItem(menuBar, SWT.CASCADE);
menuItem.setText("&File");
Menu menue = new Menu(shell, SWT.DROP_DOWN);
menuItem.setMenu(menue);
MenuItem exitItem = new MenuItem(menue, SWT.PUSH);
exitItem.setText("&Exit");
shell.setMenuBar(menuBar);
exitItem.addListener(SWT.Selection, event-> {
shell.getDisplay().dispose();
System.exit(0);
menuItem.setText("&Settings");
Menu menu = new Menu(shell, SWT.DROP_DOWN);
menuItem.setMenu(menu);
MenuItem monServerSettingsItem = new MenuItem(menu, SWT.PUSH);
monServerSettingsItem.setText("&X-Server");
monServerSettingsItem.addListener(SWT.Selection, event-> {
MenuItem dbServerSettingsItem = new MenuItem(menu, SWT.PUSH);
dbServerSettingsItem.setText("&Y-Server");
dbServerSettingsItem.addListener(SWT.Selection, event-> {
menuItem.setText("&Help");
MenuItem about = new MenuItem(menu, SWT.PUSH);
about.setText("&About");
// shell.setMenuBar(menuBar);
about.addListener(SWT.Selection, event-> {
_btnRun = new Button(shell, SWT.PUSH);
_btnRun.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
_btnRun.setLayoutData(new GridData(SWT.FILL, SWT.END, true, true));
_btnRun.setText("Run");
_btnRun.setRedraw(true);
_composite.layout();
_composite.redraw();
_shell.layout(true, true);
_shell.open();
_shell.pack();
public void doLoop()
while (!_shell.isDisposed()) {
if (!_shell.getDisplay().readAndDispatch()) {
_shell.getDisplay().sleep();
_shell.getDisplay().dispose();
When i switch in eclipse to WindowBuilder "Design view" the form is too small.
It does not show the entire menu.
1. I can't resize it in the Design view.
2. When i use Test/Preview i can resize it - but the problem is that i have to resize it.
[Updated on: Tue, 19 April 2016 06:07] Report message to a moderator
FUDForum. Page generated in 0.02303 seconds
