Home » Modeling » TMF (Xtext) » Re: [XCore] The Body of the method
Re: [XCore] The Body of the method [message #1729624] Sat, 16 April 2016 09:07 Go to next message
Parisa,
It looks like you have the recent versions of both, but the stack traces
make it clear there is some type of incompatibility. Did you install
these from http://download.eclipse.org/releases/mars?
I've added the TMF newsgroup to the reply, because they're more likely
to recognize what might be wrong...
On 16.04.2016 10:28, Parisa Moosavi wrote:
> I have updated the Xcore and Xtext has been updated but it doesn't work any more. I see this errors:
> 1 [Worker-1] ERROR org.eclipse.xtext.service.CompoundModule - java.lang.reflect.InvocationTargetException
> java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
> at org.eclipse.xtext.service.MethodBasedModule.invokeMethod(MethodBasedModule.java:138)
> at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:50)
> at org.eclipse.xtext.service.CompoundModule.configure(CompoundModule.java:35)
> at org.eclipse.xtext.service.AbstractGenericModule.configure(AbstractGenericModule.java:33)
> at org.eclipse.xtext.service.DefaultRuntimeModule.configure(DefaultRuntimeModule.java:76)
> at org.eclipse.emf.ecore.xcore.AbstractXcoreRuntimeModule.configure(AbstractXcoreRuntimeModule.java:25)
> at com.google.inject.spi.Elements$RecordingBinder.install(Elements.java:223)
> at com.google.inject.spi.Elements.getElements(Elements.java:101)
> at com.google.inject.spi.Elements.getElements(Elements.java:92)
> at com.google.inject.util.Modules$RealOverriddenModuleBuilder$1.configure(Modules.java:152)
> at com.google.inject.AbstractModule.configure(AbstractModule.java:59)
> at com.google.inject.internal.InjectorShell$Builder.build(InjectorShell.java:133)
> at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:103)
> at com.google.inject.Guice.createInjector(Guice.java:95)
> at com.google.inject.Guice.createInjector(Guice.java:72)
> at com.google.inject.Guice.createInjector(Guice.java:62)
> at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.createInjector(XcoreActivator.java:67)
> at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.getInjector(XcoreActivator.java:55)
> at org.eclipse.emf.ecore.xcore.ui.XcoreExecutableExtensionFactory.getInjector(XcoreExecutableExtensionFactory.java:26)
> at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:51)
> at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
> at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
> at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.getExtension(ResourceServiceProviderDescriptor.java:46)
> at org.eclipse.xtext.internal.AbstractResourceServiceProviderDescriptor.get(AbstractResourceServiceProviderDescriptor.java:20)
> at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:46)
> at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:109)
> at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:129)
> at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:27)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl$1.getURI(Storage2UriMapperJavaImpl.java:308)
> at org.eclipse.xtext.ui.resource.SourceAttachmentPackageFragmentRootWalker.handle(SourceAttachmentPackageFragmentRootWalker.java:279)
> at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:107)
> at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:95)
> at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:65)
> at org.eclipse.xtext.ui.resource.SourceAttachmentPackageFragmentRootWalker.traverse(SourceAttachmentPackageFragmentRootWalker.java:168)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeData(Storage2UriMapperJavaImpl.java:321)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.getCachedData(Storage2UriMapperJavaImpl.java:241)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.updateCache(Storage2UriMapperJavaImpl.java:457)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.access$6(Storage2UriMapperJavaImpl.java:450)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl$4.run(Storage2UriMapperJavaImpl.java:646)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.doInitializeCache(Storage2UriMapperJavaImpl.java:658)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeCache(Storage2UriMapperJavaImpl.java:566)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeCache(Storage2UriMapperJavaImpl.java:525)
> at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.initializeCache(Storage2UriMapperImpl.java:159)
> at org.eclipse.xtext.builder.builderState.AbstractBuilderState.load(AbstractBuilderState.java:62)
> at org.eclipse.xtext.builder.builderState.AbstractBuilderState.ensureLoaded(AbstractBuilderState.java:69)
> at org.eclipse.xtext.builder.builderState.AbstractBuilderState.isEmpty(AbstractBuilderState.java:217)
> at org.eclipse.xtext.ui.shared.internal.ListenerRegistrar.initialize(ListenerRegistrar.java:44)
> at org.eclipse.xtext.ui.shared.internal.EagerContributionInitializer.initialize(EagerContributionInitializer.java:31)
> at org.eclipse.xtext.ui.shared.internal.Activator.start(Activator.java:115)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
> at java.security.AccessController.doPrivileged(Native Method)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
> at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
> at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
> at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
> at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
> at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
> at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
> at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
> at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
> at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
> at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
> at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
> at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
> at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
> at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
> at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
> at org.eclipse.core.internal.events.BuildManager.instantiateBuilder(BuildManager.java:906)
> at org.eclipse.core.internal.events.BuildManager.initializeBuilder(BuildManager.java:859)
> at org.eclipse.core.internal.events.BuildManager.getBuilder(BuildManager.java:545)
> at org.eclipse.core.internal.events.BuildManager.getBuilder(BuildManager.java:574)
> at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:244)
> at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
> at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
> at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
> at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
> at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
> Caused by: java.lang.reflect.InvocationTargetException
> at org.eclipse.xtext.service.MethodBasedModule.invokeMethod(MethodBasedModule.java:136)
> ... 93 more
> Caused by: java.lang.NoClassDefFoundError: org/eclipse/xtext/xbase/annotations/validation/UnresolvedAnnotationTypeAwareMessageProducer
> at org.eclipse.emf.ecore.xcore.AbstractXcoreRuntimeModule.bindILinkingDiagnosticMessageProvider(AbstractXcoreRuntimeModule.java:284)
> ... 98 more
> Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.xbase.annotations.validation.UnresolvedAnnotationTypeAwareMessageProducer cannot be found by org.eclipse.emf.ecore.xcore_1.2.2.v20150202-0452
> at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
> ... 99 more
> !ENTRY org.apache.log4j 4 0 2016-04-16 10:14:32.019
> !MESSAGE org.eclipse.xtext.service.CompoundModule - java.lang.reflect.InvocationTargetException
> !STACK 0
> ... 93 more
> ... 98 more
> ... 99 more
> 108 [Worker-1] ERROR org.eclipse.xtext.service.CompoundModule - java.lang.reflect.InvocationTargetException
> ... 93 more
> Caused by: java.lang.NoClassDefFoundError: org/eclipse/xtext/xbase/file/FileLocationsImpl
> at org.eclipse.emf.ecore.xcore.AbstractXcoreRuntimeModule.bindFileLocations(AbstractXcoreRuntimeModule.java:264)
> ... 98 more
> Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.xbase.file.FileLocationsImpl cannot be found by org.eclipse.emf.ecore.xcore_1.2.2.v20150202-0452
> ... 99 more
> !ENTRY org.apache.log4j 4 0 2016-04-16 10:14:32.179
> !STACK 0
> ... 93 more
> ... 98 more
> ... 99 more
> 214 [Worker-1] ERROR org.eclipse.xtext.service.CompoundModule - java.lang.reflect.InvocationTargetException
> ... 93 more
> Caused by: java.lang.NoClassDefFoundError: org/eclipse/xtext/xbase/file/JavaIOFileSystemSupport
> at org.eclipse.emf.ecore.xcore.AbstractXcoreRuntimeModule.bindMutableFileSystemSupport(AbstractXcoreRuntimeModule.java:259)
> ... 98 more
> Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.xbase.file.JavaIOFileSystemSupport cannot be found by org.eclipse.emf.ecore.xcore_1.2.2.v20150202-0452
> ... 99 more
> !ENTRY org.apache.log4j 4 0 2016-04-16 10:14:32.219
> !STACK 0
Ed Merks
Re: [XCore] The Body of the method [message #1729627 is a reply to message #1729624] Sat, 16 April 2016 10:15 Go to previous messageGo to next message
Parisa Moosavi is currently offline Parisa MoosaviFriend
Member
Ed,
I have this kepler version because the main project has been developed in this version:
Eclipse Modeling Tools
Version: Kepler Service Release 2
Build id: 20140224-0627
Therefore I updated the Xcore and Xtext from Help > Check for updates menu. In eclipse I can create xtext project but when I go to runtime for creating xcore project these errors appear.
Re: [XCore] The Body of the method [message #1729667 is a reply to message #1729627] Sun, 17 April 2016 12:21 Go to previous message
Parisa,
I'm not sure what you mean by "go to runtime"? You mean you launched a
self hosting Eclipse to test your development efforts in your main
Eclipse's workspace? How did you populate the target platform of the
main Eclipse IDE? I just wonder if what you've showing you have
installed is also the same as the versions you have in the target
platform because a runtime launch uses what's in the target platform of
the main Eclipse, independent of what you have installed in the main
Eclipse.
On 16.04.2016 12:15, Parisa Moosavi wrote:
> Ed,
> in this version:
Ed Merks
Previous Topic:Web editor unable to generate with inferrer
Next Topic:XText TextViewer instead of Editor
Current Time: Tue Jan 26 19:39:25 GMT 2021
Powered by FUDForum. Page generated in 0.01898 seconds
