Re: Unable to connect two ports inside top capsule [message #1729536 is a reply to message #1729469] |
Fri, 15 April 2016 04:27   |
From your screen shot I can see that you for some reason have not got the correct diagram type. It looks like the standard UML composite structure diagram, and not the customized capsule structure diagram.
How did you install Papyrus-RT? Did you install using the Eclipse Installer as described here.
Or did you install it manually? I strongly recommend to use the Eclipse Installer, since then setting a few preferences to get the correct diagram type will be handled automatically.
If not, then I suggest that you take a look at this specific step in the manual installation instruction. If you have the viewpoint set correctly for UML-RT, then you should get a capsule structure diagram, of the correct type, created automatically whenever you create a capsule.
That on the other, does not really explain why cannot make a connector in this case (it should be possible even if you for some reason have gotten the wrong diagram type and have the standard UML composite structure diagram).
Apart from that I can also see that you are missing the "Real Time" tab in the properties view, which should show only the relevant properties for UML-RT, which also looks suspicious.
Considering this, I would strongly recommend that you use the Eclipse Installer as described via the link above and reinstall Papyrus-RT to ensure that you have correct setup.
/Peter Cigéhn
FUDForum. Page generated in 0.30992 seconds
