Home » Eclipse Projects » Sapphire » Styling Labels
Styling Labels [message #1729321] Wed, 13 April 2016 03:10 Go to next message
Jason Pell is currently offline Jason PellFriend
Member
Is there a way to provide hints to style labels? I would especially like to be able to style the labels as bold in the summary section under certain conditions. I have a section that looks like this:
<root-node>
			<node>
				<label>Operations</label>
				<node-factory>
					<property>OperationConfigs</property>
					<case>
						<label>${ignored != true ? "*" : ""}${OperationName}</label>
						<section>
							<label>Operation</label>
							<content>
								<include>OperationConfigForm</include>
							</content>
						</section>
					</case>
				</node-factory>
			</node>
I would prefer to be able to do something like:
<root-node>
			<node>
				<node-factory>
					<case>
						<label>${ignored != true ? "<b>" : ""}${OperationName}${ignored != true ? "</b>" : ""}</label>
						<section>
							<content>
							</content>
						</section>
					</case>
				</node-factory>
			</node>
[Updated on: Wed, 13 April 2016 03:13]
Report message to a moderator
Re: how to make uml editor in eclipse plugin [message #1729326 is a reply to message #1729321] Wed, 13 April 2016 05:33 Go to previous messageGo to next message
Zeba Rizvi is currently offline Zeba RizviFriend
sir, i wanted to know how to make uml editor programmatically using papyrus API's.
Re: how to make uml editor in eclipse plugin [message #1729762 is a reply to message #1729326] Mon, 18 April 2016 17:45 Go to previous message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
There is currently no support for styling labels, but if you need to display a block of styled text, you can use the HTML control.
Previous Topic:xml single tags <asdf/>
Next Topic:Is there a way to configure the font of a label in an sdef file
Current Time: Sun Sep 27 18:08:14 GMT 2020
Powered by FUDForum. Page generated in 0.02050 seconds
